Easter Egg Audi Secrets......and tips!!
Old Dec 30, 2007 | 12:59 AM
1Move's Avatar
Default Easter Egg Audi Secrets......and tips!!
Hey guys well Christmas is gone by but new years is coming so here is some useful tips for those that did not notice if I missed any post it up! SO here it goes
Window Pinch:
Press and hold the window up for 5 sec, press down instantly to open window all the way and hold for 5 seconds while its down and instantly close again and hold all the way to the top Pinch control is now learned!
Throttle Body Alignment:
put the key and put it into the position just before the starter turns (do not start the car) push the gas peddle all the way wait 3 seconds and turn the key all the way back but do not take it out, now release the gas peddle and wait 2 minutes! remove key than put it back in and start the car! you should notice a better response while pressing the gas do this once every few weeks!
Reversing passenger mirror fold down:
Put the control (on the driver door for your side view mirrors)onto the passenger mirror position put the car in reverse, window tilts down and shows you the curb! (this only works on some models like the 3.0 not sure of what year of 1.8t)
Storage underneath the steering wheel!
Storage under the driver and passenger seats!
Telescopic steering wheel on most models, the steering wheel has a little arm underneath push it downward and pull your wheel towards you or push away from you! Most models have this!!!
Turning the sunroof handle all the way and holding it there till the sunroof goes all the way back and tucks in even the last 2 inches and is completly inside the roof!
Push the sunroof handle upwards to tilt the window and open it only as a tilt!
Sun blocker above the rear view mirror!
Turn the key inside the driver door one way and hold all windows come down, and the other way all windows go up!
Climate control:
Holde the auto button on the driver side for 4 seconds and release now you can control both climate temps. with the driver side! to re do to normal position just press the passenger +,- to change back to dual change!
When the car is unlocked stick your hand where you usually open the trunk it will unlock and open automatically by pushing the handle underneath!
When you open the spare tire compartment the handlehooks directly onto your trunk and you dont have to hold it open!
turn on the radio and press and hold the menu for 5 secs and a bunch of options will appear you can switch in between them by pressing menu again!
Independent fog lights:
Switch the country setting to Canada using VAG-com!
Illuminated blinkers when the car is locked and off:
Ever parked in a dark place for a few minutes but scared that someone might not see your car? Press the blinker to the left or to the right depending what side you want illuminated and lock the car this will not drain the battery all that much but dont leave it on all the time useful for a few hours!!
Using VAG-COM you can program it so the windows go up and down with the remote lock unlock!
Using VAG-COM you can program so the car locks at 10mph!
To turn on fogs and lights at the same time turn the handdle all the way and than pull it towards you all the way out all lights should be on now!
when you spray the washer fluid and after 3 wipes the forth one kicks in after a few seconds to disable that fourth wipe while the first three are in progress press the handle downwards and the fourth one will cancel!
That is it for me guys Let me know if i Missed some I am sure I did cant think right now there are too many of them! GOOD LUCK!! and enjoy!! Happy holidays!!!
Old Dec 30, 2007 | 01:13 AM
loktian's Avatar
Default RE: Easter Egg Audi Secrets......and tips!!
thanks~~~
Old Dec 30, 2007 | 01:15 AM
hiwords's Avatar
if your setting your clock on the car, make sure you do it before 12pm or the next day, you will see the date as the same as before. it will change to the right one after 12pm though. but just imagine the confusion on a monday morning.
you forgot to tell people that the stuff you meantion are for the b6 lol. not all of them work on every chasis
Old Dec 30, 2007 | 01:16 AM
18T's Avatar
18T
SAAME **** DIFFERENT DAY.
*SEARCH*
Old Dec 30, 2007 | 01:18 AM
1Move's Avatar
Oh set the temperature with one key in the ignition and then turn off the car, put your other key in and set a different temp!! The car recognizes which key it is and goes to the last temp setting!!
Old Dec 30, 2007 | 02:33 AM
ee99ee's Avatar
That is so awesome. Thank you for posting this, I can't believe all of this stuff is on my car.... crazyness...
Old Dec 30, 2007 | 02:46 AM
onepoint8tee's Avatar
So, this is pretty much a blatant copy and paste from Audizine....... Wonderful. Thanks for all your hard work and thoughtfulness.
You almost sounded like you were passing thisreconstructed plagiarismoff as a Xmas present...... Re-gifter...... [sm=bustedsign.gif]
Old Dec 30, 2007 | 05:04 AM
jsgrabo's Avatar
[sm=funnypostabove.gif]
Old Dec 30, 2007 | 01:33 PM
1Move's Avatar
ORIGINAL: onepoint8tee
Man everytime you say something me and you end up arguing! Yes I read the audizine post a while ago, and no I am not re-gifting I took the time and wrote this out myself if you didnt notice, from the things that I knew and found out and also some stuff I have seen on here and compiled it all together! It might help someone it might not, just thought I would re post, why is everyone in such a bad mood lately? Holly Crap!
coach
B8 Models
16
Sep 9, 2013 09:02 PM
spotcar22
B8 Models
Apr 29, 2010 05:03 AM
