ecodes installation complete!
Old Dec 10, 2004 | 03:28 AM
ultra808's Avatar
Default ecodes installation complete!
i finished the ecodes install and they look sweet. since the new housings are european spec, they do not have a parking light. those lights only serve as a blinker and nothing else. we found out that there would be no parking lights when i turned it to the first click. what we did was tap into the parking lights and connect to the city lights on the ecodes. so now when i turn on the parking lights, the only thing that is on is the city lights; which is so cool....the only thing is that the city lights stay on when i turn on my hids. i have one question though... how do i aim the hid lights higher because they shoot a little too low. your help is welcomed. thanks in advance.
Old Dec 10, 2004 | 09:52 AM
Jestnomen's Avatar
6th Gear
Default RE: ecodes installation complete!
Ehhh you have them wired wrong. There is too parking lights. The turn signals are dual filiment, meaning they double as turn signals and parking lights. You were suppose to tap into the parking wire, not use it exclusivly for the parking lights. Doesn't matter, just be careful you don't get pulled over by cops. And yes the city lights would stay on when the low beams are on, cause they are essentiall parking lights. There are two white screws for adjustment. Be very gental when you turn them they strip out easy. One is for verticle movement, the other for horizontal.
Old Dec 10, 2004 | 10:18 AM
awol's Avatar
Hey Jets,
So how much do the Ecodes run and do they come with HID?
Old Dec 10, 2004 | 10:21 AM
Jestnomen's Avatar
6th Gear
They are around $339.00 for halogen housings and 489.95 for xenon from ECSTuning.com. No they don't actually come with the xenon bulbs or ballasts. That's an extra 200-500 bucks.
Old Dec 10, 2004 | 12:19 PM
awol's Avatar
thanks Jestnomen!
Old Dec 10, 2004 | 10:07 PM
04a4's Avatar
i have the euro specs and the turn signals are single filament..... THEY ONLY ACT AS THE TURN SIGNAL... the little bulb under the high beam turns on as my parking light and stays on when i turn on the HID's, I like it, it lights up the housing w/out giving light and they look sic comming down the road, cause all you see is the white light. and more questions, feel free to ask
Old Dec 10, 2004 | 10:09 PM
04a4's Avatar
to lower and rasie your lights, screw in the housing tightly, then on the top of the housings there are two screws... if you start on the passenger side, you'll notice that there is a hole in the plastic in your stock intake.. stick a screwdriver down in their and start turning, from this you should be able to reconize the other screw. and copy on the opposite side.
Old Dec 14, 2004 | 12:45 AM
alejandrorodrigu's Avatar
show some pics !
Old Dec 14, 2004 | 12:47 AM
jestnomen, what means 99.5 fog lights ???
readimag
Nov 7, 2008 04:40 PM
greg14142
Apr 11, 2008 01:38 PM
sdsteez
Jul 13, 2007 09:10 AM
Emil@RENN=ART
Aug 2, 2006 02:48 AM
JohnnyBravoA4
Jul 15, 2006 03:58 AM
