ECU
Old Aug 31, 2006 | 05:48 PM
chuckievi's Avatar
Default RE: ECU
Will do! The throttle body adaptation is when you put the key in, turn it and let the engine sit for 5-10 mins correct? Thats what I had to do when I took the ECU out the first time to check out its part number. (which I later found out is on the OUTSIDE of the casing too) [>:]
Old Jan 10, 2007 | 09:13 PM
bartvaio's Avatar
Default RE: ECU
I bought a used Giac Chipped ECU that was in a Manual trans. car, but mine is a tip. I have read that i need to recode the ECU with VAG COM software, but i dont know where (i guess that is in Engine, then Coding) and i dont know what values should i change. Can someone explain me that please?
