Which ECU pin does the VSS go to?
Hey guys, Ive had a good look, but I cant find the answer to my problem. Basically had to swap over an engine, but the new engine uses a VSS whereas the other one just had a blanking plug. Ive put the new clocks in and new ecu and everything works....except the speedo. So does anyone know which pin I should plug the Speed Sensor wire into?
All the best,
Andy
All the best,
Andy
sorry I really should be more specific. It is an 03 reg A4 19 TDI. The VSS plug has two wires coming off it, ones red and brown the other is just brown if I remember correctly. I basically just need to know which pin they are supposed to go to on the back of the ECU.
So avant80@2.6, would I be right in thinking that I'd hook up the brown/red one to pin 20 and the other one to pin 6?
Thanks for the quick reply
fantastic, thats really really helpful mate thank you, you really know your stuff!
I was using this pin diagram cos its the only one I could find anywhere on the internet (ignore the arrows they are for something else):
just wanted to check thats the same numbering format you are using?
Thanks again avant80@2.6, you are a legend
