ECU PINOUTS?
Old Oct 7, 2004 | 05:26 PM
gregp1962's Avatar
Default ECU PINOUTS?
I was thinking that it might be cool to be able to have a small volt meter mounted on the dash that could toggle between the outputs of a few different sensors.
Brrman was saying that the ECU monitors cylinder temps. I'm assuming there are sensors that send a voltage to the ecu indicating the temps. If I could monitor that voltage, I could monitor the cylinder temps. Other things to monitor could be, EGT, boost, a/f ratio, intake charge temps.
Does anyone have the pinnouts to the ECU? My car is a 1997 1.8t Quatro.
Old Oct 7, 2004 | 05:46 PM
Jestnomen's Avatar
6th Gear
Default RE: ECU PINOUTS?
I doubt you'll get a good answer to this. It's not really widley published information. Even if you could hook up a voltmeter, would the voltage displayed mean anything? How would you know the coversion from voltage to temperature?
Old Oct 7, 2004 | 06:02 PM
gregp1962's Avatar
Someone has got to have the pinnout info. The voltage to temp conversion could be a problem. But, if I get used to what the normal operating voltage is, I could know when I'm getting outside that range.
