ECU's interchangable?
Old Nov 3, 2004 | 10:27 PM
A4 R6 wku's Avatar
Default ECU's interchangable?
I am purchasing a turbo kit that has 310cc injectors and a custom chip out of a 99.5 a4. My car is not the same year so will i be able to use the custom chip in my car even though its not a 99.5 build year?
Old Nov 3, 2004 | 10:40 PM
Doose's Avatar
Default RE: ECU's interchangable?
It depends. You need to check the engine code. It's the three letter code located under the engine cover on the front right corner of the valve cover. I think the 99.5 is AEB. What engine code do you have?
Old Nov 4, 2004 | 12:48 AM
A4 R6 wku's Avatar
i dunno what engine code i have but i will definatley take a look. thanks for the prompt reply!
Old Nov 4, 2004 | 01:35 AM
trailboss's Avatar
Is your car N-DBW, if so it really doesn't matter for some reason. When i bought my chip it was off of a n-dbw quattro tip and I have a n-dbw frontrak, 5spd. I bought the chip used. They can reprogram it for your setup that you have. Are you looking at GIAC software?
Old Nov 4, 2004 | 04:53 PM
brrman's Avatar
Engine code is not significant if the car is non drive by wire. 99.5 and below fit this category.
The ECU part# is what is more important. However, even then you can recode the ecu with a vagcom.
(ie. you should not run an ecu coded for a manual in an auto)
frontrak vs quatto is not a factor in n-dbw as it is purely mechanical.
Keep in mind that there are some ECUs that cannot be reprogrammed. I have seen at least two of them before. Find out if they will hold a code change before buying one used if you intened to recode it.
jules23526
Jul 22, 2015 10:30 AM
wolfe2118
Aug 5, 2013 10:05 AM
Bklynrx7
Oct 26, 2009 12:29 AM
Damndislaosboy
Jul 31, 2009 05:04 PM
Line Em Up
Apr 20, 2007 04:18 PM
