electric fan
Before you replace the fan, check the 40 amp fuse for the fan. it is behind the drivers side knee bolster.
If the fuse is blown, replace it. If the fuse blows again, then the fan is drawing too much current and needs to be replaced.
Replacing the fan is a bit of a PITA. Need to put the radiator forward in the service position to get room.
It is the part of the dashboard under the steering wheel. There is a fuse block behind it.
It is held in place by about 4 screws, two on the front, one on the left under the main fuse box cover, and one down by the transmission tunnel. After that it just slides out.
