electric fan
Old May 22, 2005 | 04:35 PM
KloepferN's Avatar
Default RE: electric fan
hey is it a box fuse or a little fuse that looks like the rest of them
Old May 22, 2005 | 04:45 PM
Jestnomen's Avatar
6th Gear
Open the drivers door and pull off the fuse box cover. Check each fuse to see if they are blown. You may have to buy a fuse checker or a multimeter because fuses aren't always visibly blown.
Old May 22, 2005 | 04:48 PM
KloepferN's Avatar
i found it, its blown, i can get this fuse the 40 amp at like pep boys or auto zone ot advanced auto parts right??
Old May 22, 2005 | 04:52 PM
Jestnomen's Avatar
6th Gear
Yes sir, correct you are.
Old May 22, 2005 | 06:50 PM
david9999's Avatar
Yes, pep boys will have it.
Put it in and turn on your air conditioning. If the fuse blows in a few minutes, then you need to replace the fan.
Old May 23, 2005 | 12:37 AM
KloepferN's Avatar
ok the 1st one blew but i replaced it with another one. Now it worked really good cold a'c but then the fan had a burning smell to it and smoking, so im guessing the fan now has to be replaced..now i didnt take out the fuse so if the fan still goes on and smoking it will just burn it self out right?
Old May 23, 2005 | 08:45 AM
david9999's Avatar
Either that, or it will set your car on fire.
If the fan is drawing that much current, it will need to be replaced.
Old May 23, 2005 | 02:54 PM
  #18
KloepferN's Avatar
so just take out the fuse and ill be fine
Old May 23, 2005 | 04:36 PM
  #19
david9999's Avatar
Yes.
Old May 23, 2005 | 05:06 PM
  #20
KloepferN's Avatar
well the fuse blew again cuz it went back to blowing hot air when in park or and the fan isnt moving.
