Electric Top 1997 Not Working
Old Jan 10, 2006 | 05:46 PM
Cabrio1997's Avatar
Default Electric Top 1997 Not Working
I have a 97 cabrio, the electric top is not functioning. I release the top with the handle and do everything right. When I pull the button to lower the roof it clicks once and nothing else happens. Any way to manually override the electric top so I can at least get in there to have a look?
Old Jan 10, 2006 | 06:05 PM
BFlan2001's Avatar
Default RE: Electric Top 1997 Not Working
a 97 cab? i need pics, please!!!
Old Jan 10, 2006 | 06:37 PM
Cabrio1997's Avatar
That attachment was too big, exceeded bandwith. Can you e mail that to me? tedfitzinsurance@yahoo.com
Old Jan 10, 2006 | 06:39 PM
Cabrio1997's Avatar
Sorry man, I thought you had a copy of the manual. I don't, thats most of my battle. Know where I can get one?
Old Jan 10, 2006 | 06:47 PM
ecartoys's Avatar
Does it only go one click with no more motor noise? Have someone listen close to the top and see if there is anymore noise when you push the button.
ORIGINAL: Cabrio1997
Old Jan 10, 2006 | 07:02 PM
BFlan2001's Avatar
i have the bentley manual, but it doesn't include the cabrios...there was no cab available to the US in the B5 body style
Old Jan 10, 2006 | 07:30 PM
Cabrio1997's Avatar
I think it only clicks, no motor noise. I'll have someone listen to it tonight if I can. Is there any way for me to get in there manually? I cannot get the back of the top to move up and I don't want to break it. Also, it appears the cover is locked as well because I tried lifting that to no avail.
Old Jan 10, 2006 | 07:36 PM
Cabrio1997's Avatar
If not a B5 what is it?
Old Jan 10, 2006 | 08:35 PM
BFlan2001's Avatar
where are you located? i'm assuming you're not in the US.
Old Jan 11, 2006 | 12:12 AM
mastvadz71's Avatar
Member
open the trunk ,where the hinges are there is a wiring harness for the converteble top.it is a comon problem ,from opening and closing the trunk lid the wiring is tearing a part.you need to replace the harness.parts wise is about 175$,and 20-30 min labor.do not try to repear the wires they will brake again.if any quest.call 305 213 4243-nicko
