engine code
Old Mar 23, 2005 | 10:07 PM
jackster's Avatar
Default engine code
hi there
can you tell me the engine code for the a4 130 bhp tdi se saloon and the position of the info relating so i can check my engine ie is on a plate or the timing cover
Old Mar 23, 2005 | 10:16 PM
Jestnomen's Avatar
6th Gear
Default RE: engine code
Typically the engine code is located on a placard on the front of the engine somewhere.
Old Mar 23, 2005 | 10:25 PM
Doose's Avatar
It's also stamped on the valve cover.
Old Mar 24, 2005 | 05:02 PM
brrman's Avatar
The engine code letters and serial number are stamped on the right-hand side of the engine cylinder block, between the cylinder head and the power steering pump.
Old Mar 24, 2005 | 05:19 PM
clconversion's Avatar
also on the sticker in the trunk around the spare wheel that sticker is also located in your maintance manual
Old Mar 24, 2005 | 06:01 PM
jackster's Avatar
right thanks guys but can you now tell me what the kw is for the 130 bhp tdi engine as i now know that the sticker you tell me about is the same type as the vw golf that i had a year ago in the spare wheel well
Old Mar 24, 2005 | 06:04 PM
yea golf's would have that same sticker
xristos.greece
Aug 13, 2017 08:24 AM
HumbyWumby
Apr 4, 2013 05:44 PM
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
spinedoc
Nov 3, 2008 12:12 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
