Engine Codes!!!
Old Nov 26, 2006 | 05:14 AM
NuYorka103185's Avatar
Default Engine Codes!!!
Can you guys please help me out and tell me what these mean?
P1433
P1556
Thanks
Old Nov 26, 2006 | 08:01 AM
techbod's Avatar
Default RE: Engine Codes!!!
P1433 secondary air injection pump relay open circuit, causes shorted wire/ blown fuse AIR pump relay blown.
P1556 AC compressor load signal implausible signal, causes wiring, Ac system
Old Nov 26, 2006 | 12:23 PM
CRAZYHAWK's Avatar
P1433 17841 Loose electrical conector in secondary air injector relay circuit.
P1556 17964 Charge pressure contr. negative deviation
http://forums.vwvortex.com/zerothread?id=1245887
Old Nov 26, 2006 | 06:57 PM
So I should I correct this?
Old Nov 26, 2006 | 06:58 PM
how should I, sorry
Old Nov 26, 2006 | 07:02 PM
techbod's Avatar
does the A/C work?? if not it might need a re-gass the other P1433 could be as simple as changing the relay
Old Nov 26, 2006 | 07:03 PM
AC works fine
Old Nov 26, 2006 | 11:21 PM
CRAZYHAWK's Avatar
The code P1556 has nothing to do with the AC.
Look for a turbo boost leak.
Old Nov 27, 2006 | 12:01 AM
I get plenty of boost, even after the flash effects go away it still has boost
Old Nov 27, 2006 | 12:03 AM
sorry you proboably dont know, i got my car flashed and now I get these codes, my car feels flashed for like 2 minutes then feels stock and I get these engine codes so even when it feels stock again the boost is still there just not like when the flash is still working
