Engine Fault Code
I had someone with a VAG-COM tool help me find out why my check engine light was on but he did not have the decoder to find out what the fault code meant. Does anyone have access to one? I have an '02, A4, 1.8, B6/B7 and this is the fault code instructions the VAG-COM tool gave:
Address 01: Engine Part No SW: 8E0 909 518 G HW: 8E0 909 018 Component: 1.8L R4/5VT G 0002 Coding: 0016581 Shop #: WSC 63351 1 Fault Found: 17544 - Fuel Trim: Bank 1 (Add): System too Lean P1136 - 001 - Upper Limit Exceeded - MIL ON Readiness: 0000 0000 Help please! |
RE: Engine Fault Code
Your car is a B6, not a b6/b7. There is no decoder for vag com that im aware of. It will give you the code then you have to find out what it means. There is a write up somewhere about what all the fault codes mean.. Try searching "17544 - Fuel Trim: Bank 1 (Add): System too Lean" in any search engine like yahoo, or the search here. Im guessing your MAF is bad. I had that code when my MAF was bad.. But try to think of other things that can make you run lean like fuel restriction, 02 sensor, etc.
air leak by my data it could be a vacuum pipe off or split
ORIGINAL: avant80@2.6 air leak by my data it could be a vacuum pipe off or split |
too much fuel would be running rich
too much air would make it run lean |
[IMG]local://upfiles/12092/3977847FD51F405F904BBB724C2DE1AA.jpg[/IMG] |
o i just figured that if a hose was split then that means air is leaking out and there is more fuel in the a/f ratio. but this is why your dave and im jus chaos. always trust dave's word over mine;)
ORIGINAL: chaos92287 always trust dave's word over mine;) |
6 monthly lol screen shots are nothing personal to your troubleshooting suggestions;)
ORIGINAL: avant80@2.6 6 monthly lol screen shots are nothing personal to your troubleshooting suggestions;) |
