ENGINE MISFIRES IN MY 97 A4 1.8
Old Dec 26, 2005 | 10:24 PM
ecefunding's Avatar
Default ENGINE MISFIRES IN MY 97 A4 1.8
hey every1,
my engine idles at like 300 rpm and i can hear it misfire
i was told that it either my coil packs or the ICM located on my intake box
well i checked my coil pacs n they were fine
i also got a new ICM but my car still misfires
Dont I have to reset the ECU for it to accept the new ICM???????
Old Dec 26, 2005 | 10:41 PM
Slowb5's Avatar
Default RE: ENGINE MISFIRES IN MY 97 A4 1.8
check your plugs and wires man.
Old Dec 26, 2005 | 10:43 PM
ecefunding's Avatar
plugs n wires should b fine bc car had a tune up less then 5 K ago
Old Dec 27, 2005 | 04:28 PM
onepoint8tee's Avatar
ORIGINAL: ecefunding
If you didnt do the tune up yourself, you never know what was or wasnt done for sure. Youd be surprised at how many places dont do the maintnance you ask for but still charge you for it. Also the wires wouldnt be replaced in a "tune up"... Maybe you have bad gas (gasoline) Injectors? Fuel pump on its way out? Fuel filter??
Old Dec 27, 2005 | 07:00 PM
ecefunding's Avatar
thanks for the advice...
i kno its not bad gas bc ive put new fresh gas since this happend.
U mite b rite bout the tune up tho so im goin to have to check that
Although the same 2 cylinders are always misfiring and if it was a fual injector then wouldnt it show up if i scanned the car???
When i scan it i get the 3 same error
1 misfire
2 misfire
3 throtle position sensor
Old Dec 27, 2005 | 07:57 PM
1 misfire
2 misfire
did you try a throtle body alignment?
tofast2belast
Jul 31, 2013 06:05 PM
Dimondblood
May 12, 2011 08:41 AM
D-Rock
Dec 17, 2008 05:56 PM
hopskid
Dec 29, 2005 01:43 AM
hopskid
Dec 24, 2005 02:07 AM
