engine temperature?
Old Nov 19, 2004 | 04:36 AM
thintzen's Avatar
Default engine temperature?
i have the 1998 1.8t a4, does the temperature of anyone's car pass the halfway mark when you're going slow or idleing after driving fast? mine passes halfway by one notch, but goes back to the original spot when i start going faster!
Old Nov 19, 2004 | 05:07 AM
PandaXpress's Avatar
Default RE: engine temperature?
you are feeding more air to the radiator when u drive faster but its bad when you pass the half mark, you should really get that checked
Old Nov 19, 2004 | 09:22 AM
Jestnomen's Avatar
6th Gear
having your temp at half way isnt abnormal I don't think.
Old Nov 19, 2004 | 12:45 PM
CRAZYHAWK's Avatar
Triple negative.
Old Nov 19, 2004 | 01:32 PM
99a4audi's Avatar
sometimes when i start it up after shuting it down, to like get gas and stuff. the check temp is past halfway. Its werid but after a couple miles babying it, the engine temp goes back down.
Old Nov 19, 2004 | 01:57 PM
PaulA4's Avatar
Unplug the temp sensor plug and clean the contacts then replace it, mine was giving me weird readings, that solved it.
Mine never goes above half, ever.
Old Nov 19, 2004 | 11:05 PM
thintzen's Avatar
when i restart after shutting off, i get the same problem also,,,what did you do to fix it?
Old Nov 21, 2004 | 12:36 AM
SlimChriz's Avatar
Mine never goes past halfway... except for one time at the last autoX event I went to and that was probly because my oil temp was overwelming my oil cooler
cg084
Mar 2, 2021 12:45 PM
Audi-s3
Sep 19, 2008 10:36 AM
SloRide
Jun 11, 2008 12:42 PM
audiTTGuy
Apr 20, 2008 06:29 AM
jthemis
Oct 26, 2006 02:29 PM
