ESP light going on and off
Old Apr 24, 2006 | 06:04 PM
tjolson19's Avatar
Default ESP light going on and off
Quick question I thought somebody might have some knowledge on....
On occasion when I turn my car on the orange light with ! turns on, from my understanding this is the light letting you know that the ESP is turned off.....It's weird because it will turn on with the car, and then eventually (usually within 5mins) will turn back off....However, sometimes it just stays on and I can't get it to turn off.....any ideas? And I never turn the ESP off manually
Thanks
Old Apr 24, 2006 | 06:08 PM
Jeff's Avatar
Zombie Defense Force
Default RE: ESP light going on and off
i dont have it in my car but i think it comes on when u loose traction telling you that ur slipping but thats a shot n the dark. also what does it do when you push your esp button?
Old Apr 24, 2006 | 06:10 PM
tjolson19's Avatar
ORIGINAL: Jeff
Well, I don't think it's that I'm losing traction, because it stays on when idleing.....Also, it stays on for the first 5-10mins and then usually turn off, however a few times it has stayed on until I shut it off and come back later to drive it and then it won't be on. I've tried to hit the ESP button to see if it will turn it off, but that does nothing
Old Apr 24, 2006 | 06:14 PM
Jeff's Avatar
call 303.456.8383 and talk to one of the guys there. they are at I-70 and Wadsworth. Place is called 3zero3 they will help you out. They are the guys who built my car. Trevor is the owner
Old Apr 24, 2006 | 06:19 PM
tjolson19's Avatar
Thanks man, I appreciate it....
Old Apr 25, 2006 | 03:25 PM
dankhound's Avatar
Either your switch has gone bad or your car is trying to tell you theres a problem with the esp system. Check the faults in your abs control module.
Old Apr 25, 2006 | 04:31 PM
tjolson19's Avatar
ORIGINAL: dankhound
Sorry to be a noob.......but I don't know how to check the faults in the abs control module
Old Apr 25, 2006 | 05:13 PM
dankhound's Avatar
You need a scan tool.
Old Apr 25, 2006 | 06:46 PM
CRAZYHAWK's Avatar
Do a search for Steve-Hall Vag-Com Locator.
You might try a stand alone code reader.
http://cgi.ebay.com/ebaymotors/VW-AU...temZ4632932423
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
