Exhaust Sizing
Old Jan 24, 2006 | 01:23 AM
badassb5's Avatar
Default Exhaust Sizing
If I were to put a 3" piping from the cat back with the stock turbo would I experience boost creep or get any CEL's because there would be not enough backpressure?
Old Jan 24, 2006 | 01:38 AM
badassb5's Avatar
Default RE: Boost Creep/ CEL
Any input would be great. Thanks
Old Jan 24, 2006 | 07:27 AM
russianari's Avatar
you shouldnt have any problem doing that in regards to your CEL. In regards to turbo creep, not sure - but you dont need back pressure on this motor - the cat and 2.5" factory downpipe is suffiecient backpressure......why 3"? your downpipe is 2.5", do 2.5 and save some ground clearance.
Old Jan 24, 2006 | 03:22 PM
Mr_You's Avatar
Why not spend the money on a 3" cat and 3" downpipe and a smaller/normal exhaust for back pressure instead? I don't see what you're gaining with a 3" exhaust from a 2.5" cat/downpipe. From what I understand, a 3" cat and 3" downpipe going into a 2.5" or 2.75" exhaust should provide sufficient back pressure. Correct me if I'm wrong please.
Old Jan 24, 2006 | 05:18 PM
badassb5's Avatar
Default RE: Exhaust Sizing
Well, with 3" piping I know that the turbo will not get as hot(not by much but a little temp difference) and you are supposed to get less turbo lag because the turbo can spin more freely. I was just wondering about the boost creep because all the info I have is with turbo setups on japanese imports and I am fairly new to the tuning of Audi's. I realize that jap imports and Audi's are two totally different types of tuning and that is why I got out of the jap tuning world, and also why I am these types of questions so any feedback is helpful. So thank you, and keep the advice coming.
P.S. Lovin the forum. Lots of good knowledge.
Old Jan 24, 2006 | 06:44 PM
Jeff's Avatar
Zombie Defense Force
i hade some boost creep with my turbo and it stoped when i installed a MBC. i have herd that 3" is a little over kill on a k03 but if a BT is in the works later then deff do 3" so you dont have to redo it
Old Jan 24, 2006 | 07:29 PM
Peteman187's Avatar
If your staying stock turbo use 2.5
Old Jan 24, 2006 | 08:17 PM
goldenchild's Avatar
u only need 3 inch when makin over 400 hp
Old Jan 24, 2006 | 09:57 PM
trailboss's Avatar
ORIGINAL: goldenchild
Why? Tons of people are using a custom 3" or on the b6 and are nowhere near 400 with some of the BT setups. Like said if you are going BT gt28rs and bigger then a 3" will be fine, a little overkill, but most places dont carry 2.75" tubing which would be the ideal piping size. Milltek is 2.75" for the quattro but is pricey.
Old Jan 25, 2006 | 12:05 AM
sandnsnow24's Avatar
haha glad this was posted cause i was wondering myself about what size pipe to redo my system with.
i got the 2.8 v6 and was thinking of running 3" from the y pipe (where the dual joins to single) into a 3" Borla.
hummm to little backpressure for the v6??? might sounds nice......
