Fault Code
Old May 12, 2006 | 05:28 AM
PKSJeter's Avatar
Default Fault Code
Hey guys i've been having some major problems with my car("96 Audi A4). i just got a Vag-Com and this came up.
Address 08: Auto HVAC
Part No: 8D0 820 043 F
Component: A4-KLIMAVOLLAUTOMAT_D64
Coding: 00062
Shop #: WSC 06335
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
My car isnt starting, it turns over but doesnt start. the lights around my speedo(check engine, ABS, Brake, etc.) dont light up. my odometer and trip light flash and then shut off completely. any help would be appreciated. Im going crazy.
PKSJeter's Avatar
Default RE: Fault Code
Also, i notice that the part is HVAC and i'm wondering why it would prevent my car from starting.
Old May 12, 2006 | 05:29 AM
BadLuckAudi's Avatar
yea id say thats not your major prob then lol unless your car is really unhappy about not having directed flow of the AC
Old May 12, 2006 | 09:35 AM
techbod's Avatar
blown fuse yes its that simple check all the fuses
Old May 12, 2006 | 12:03 PM
Jestnomen's Avatar
6th Gear
That fault is not related to the car starting.
Old May 12, 2006 | 07:00 PM
PKSJeter's Avatar
ok so all my fuses have been checked. it seems that i am having electrical problems and not mechanical problems. i tested the spark plugs today and none of them fired. also my windows dont work and my sunroof isnt opening. my door locks dont move either. none of my lights on my dash come on. but my temp gauge does show. when i ran the vag-com i only got 1 error and that was the HVAC one. any help would be appreciated guys
Old May 13, 2006 | 10:26 AM
david9999's Avatar
???? Ignition switch?, although I wouldn't expect the engine to crank but not get spark during cranking. Have you had any after market electrical work done to your car? I'm assuming that you don't have any type of immobilizer in it. I'm assuming that you checked the spart when you were cranking the engine and that although the starter was turning, there was no spark.
None of the electrical things you mention (eg windows, sun roof, engine, dash lights, spark) will work if the ignition switch isn't in the on position, which makes me think that there is an issue in the ignition switch
Check the electrical connections at the starter switch and at the ECU.
Old May 13, 2006 | 12:50 PM
techbod's Avatar
yep totally agree the ignition switch seems to be giving problems on a few members car, the code given was only for the A/C stuck/blocked gate on the blower,
check if there is a good ground to the engine
Old May 15, 2006 | 05:18 PM
PKSJeter's Avatar
i am going to make sure that my car is grounded properly. i do not think that the ignition switch is that problem becuz i've had that problem twice already and i know the symptoms but that doesnt mean its not the problem. i will check it as well. as far as the grounding goes, how many grounding points are there? and where are they located? i am going to buy a bentley manual but if you guys know it would be appreciated. thanks for the replys.
liamol
B7 Models
Dec 5, 2011 03:41 PM
cardiffkid
Oct 13, 2008 12:52 PM
JohnnyS4
Oct 13, 2008 10:02 AM
adotjdot
Nov 16, 2007 04:48 PM
AudiTim
Aug 13, 2007 05:55 PM
