fault code
Old Dec 21, 2006 | 03:39 PM
audiboy12's Avatar
Default fault code
ok so i recently braught my car in for a tune-up at a local shop where i worked with the mechanics. after all was done it was test driven it was hooked up to the vag. i got this fault code 16201 system in basic setting (idle -0.5 load 14.0) meaning my engine is either leaking air or its the mass airflow sensor telling my engine to eat fuel. i noticed this problem just a day ago it seemed i just ran out of gas. i've been monitoring it and it seems the problem is still there i'm going through gas faster then normal. any suggestions on what else this could be? or something i could do myself to fix this problem?
any recommendations and info is much appreciated
Old Dec 21, 2006 | 03:45 PM
acetrebo's Avatar
Default RE: fault code
I am not finding that code in any of the documentation for the a4. The codes start at 16394, and go up from there. Or, it will begin with a P followed by four digits.
Please verify the correct code, maybe read it again and re-post.
Old Dec 21, 2006 | 03:47 PM
T28_A4's Avatar
What did your tune-up consist of?
Old Dec 21, 2006 | 08:05 PM
audiboy12's Avatar
yea the coding says 16201 with nio DTC reconized. and my tune-up was fuel filter, pollen filter,air filter, oil chage, spark plugs,tire rotation top off fluids and a replacement of a connector hose
Old Dec 22, 2006 | 01:20 AM
T28_A4's Avatar
heres some possibilities...
a) your injectors are block - not likely
b) your fuel pressure is low - possibly, i don't know how much it would affect it but your fuel filter could have been put on in the wrong direction..
c) or you have a vac leak
have you taken it back to the shop yet? what did they say?
Old Dec 22, 2006 | 02:01 PM
audiboy12's Avatar
yea i went back yesterday and told them i have been watching my gas milage go up and down rather drastically and they said its probably the sensor in my gas tank and to keep an eye out on my gas milage and clock my milage after a full tank. but it still doesnt solve the issue of the fault code -i just hope its not vac leak or mass airflow cuz both are rather expensive to fix
Old Dec 22, 2006 | 02:21 PM
techbod's Avatar
code unknown on all of my data
Old Dec 22, 2006 | 05:42 PM
T28_A4's Avatar
jack up your car and see if your fuel filter is on the right way, notice how one side has a rim on it and the other is just flat rounded...
i have no idea how much having it on the wrong way affects the car, but if there is a right and a wrong way, it must change something...
Old Dec 22, 2006 | 11:36 PM
audiboy12's Avatar
i checked the fuel filter and it's on correct so thats not the problem -i'm gunna watch my fuel and milage till break is over then have it hooked up to the vag again unless anyone is around somerset county NJ and has a vag.
also
Old Dec 23, 2006 | 02:18 AM
T28_A4's Avatar
you can always do a pressure test yourself if you have an air compressor... http://www.a4mods.com/index.php?page...boostleak.html
also try this
http://www.steve-hall.com/cgi-bin/VAG-Locator.pl
liamol
B7 Models
Dec 5, 2011 03:41 PM
cardiffkid
Oct 13, 2008 12:52 PM
JohnnyS4
Oct 13, 2008 10:02 AM
adotjdot
Nov 16, 2007 04:48 PM
AudiTim
Aug 13, 2007 05:55 PM
