fault code
could bea couple of things. could be dv is failing, a vacuum leak, combi valve, air pump, but it is most likely a vacuum leak.
There's a vac line that runs from under the intake manifold.Around the back of the engine to the Combi valve (secondary air injection) - it's a round, chrome topped valve on the back left (passenger side)of the engine - you can't miss it. Check this hose. I'd be willing to bet it's got a leak. Replace it and you should be good to go. If not just check the other vac lines.
