Fault Code Decipher?
Old Oct 7, 2005 | 06:11 PM
5SpeedJazz's Avatar
Default Fault Code Decipher?
Hey all,
I finally took the plunge and bought a Vag Com-USB, and ran it against my A4.
I also got the Bently Manual on CD, and what I came up with in my scan is skipped in the manual.
Anyone have any insights into this message:
VAG-COM Version: Release 504.1-UD
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 17 25 35 45 55 56
Address 01: Engine
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D03
Coding: 06251
Shop #: WSC 06335
1 Fault Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
Readiness: 0000 0100
I was thinking I needed to do a throttle body cleaning because a repair shop said that's what they came up with.
Thanks!!!!!!!!!!
Adam
Old Oct 7, 2005 | 10:58 PM
david9999's Avatar
Default RE: Fault Code Decipher?
P0411
16795
Sec. Air Inj. Sys.
2 Dcy
- Check Secondary Air Injection (AIR) system Repair Manual, 2.8 Liter V6 5V Engine Mechanical, Repair Group 26
No further information found. Doubt that throttle body cleaning will help, but it wont hurt and costs nothing.
Old Oct 8, 2005 | 12:04 AM
5SpeedJazz's Avatar
Thanks!! I'll check that in the manual. Who knows right?
The CEL light stopped illuminating the day before I plugged in the Vag Com for the first time. The only thing I did different was blow the AC cooler to 68%. I'm at least good at tracing my steps.. (my software dev background).
Old Oct 8, 2005 | 12:39 AM
5SpeedJazz's Avatar
I'm wondering why some codes can't be found in the Bently Service Manual? Is it that the Vag Com that I bought isn't the top of the line?
There were some other codes that came up that didn't seem as important
EX:
Address 02: Auto Trans
Controller: 8D0 927 156 BQ
Component: AG5 01V 2.8l5V USA 8511
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 08: Auto HVAC
Controller: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D54
Coding: 00060
Shop #: WSC 06335
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Thanks again for your input...
I promise not to lean on you guys too much as I see this is more of a MOD forum...
Old Oct 8, 2005 | 10:46 AM
david9999's Avatar
Brake light switch -F-
Implausible signal
The brake light switch is not adjusted correctly.
- Check brake light switch, "Read measuring value block", display group 2 page 01-256
Note: The brake light switch must be adjusted exactly.
00779 3133
Outside Air Temperature Sensor G17
Short circuit to ground /SP
Open circuit/short circuit
to positive /SP
- Short circuit or open circuit
between -G17- and -E87-
- -G17- malfunction
- Diagnose and repair short circuit or open circuit in wiring using wiring diagram
- -G17- electrical test Page 01-115
noodlekaboodle
Oct 6, 2011 03:44 PM
cardiffkid
Oct 13, 2008 12:52 PM
adotjdot
Nov 16, 2007 04:48 PM
mccrora
May 15, 2007 11:11 AM
seana4
Apr 20, 2007 02:04 AM
