Fault Code Look Up
Old Jan 30, 2007 | 10:36 PM
socaljoe's Avatar
SoCal Crew Member
Default Fault Code Look Up
This is pretty cool, DTC Search can assist you in interpreting Diagnostic Codes "thrown" by your Audi ECU. Also has a downloadable excel file with the list of the codes
http://www.s4biturbo.com/dtc_search.cgi
Old Jan 30, 2007 | 10:59 PM
southcoast's Avatar
Default RE: Fault Code Look Up
do you know where i canget info on doing circuit test on a throttle position sensor and what the voltage is supposed to be?
Old Jan 31, 2007 | 01:15 AM
david9999's Avatar
Yes, but not if you don't start your own thread.
Old Jan 31, 2007 | 01:18 AM
chaos92287's Avatar
nice find
Old Jan 31, 2007 | 01:21 AM
david9999's Avatar
Throttle valve control module power supply, checking
Disconnect 8-pin harness connector from throttle valve control module -J338-.
Connect multimeter US 1119 (Fluke 83 or equivalent) between harness connector terminals using adapter cables from VW 1594 connector test kit.
Switch ignition on, and check voltage. Specified values:
Connector terminals 3 and 7 (Ground): 9.0-14.5 volts
Connector terminals 4 and 7 (Ground): 4.0-6.0 volts
Switch ignition off.
If voltage is NOT OK:
Connect VAG 1598/22 test box Page 01-56 .
Check wiring for open circuit between ECM/test box and 8-pin harness connector.
Connector terminal 3 to ECM/test box socket 69
Connector terminal 4 to ECM/test box socket 62
Connector terminal 7 to ECM/test box socket 67
Specified value: max. 1.5
[hr]
[align=right]24-102[/align][/align]
Check wiring for short circuit between ECM/test box and 8-pin harness connector.
Connector terminal 7 to ECM/test box socket 69
Connector terminal 7 to ECM/test box socket 62
Connector terminal 4 to ECM/test box socket 67
Specified value:
Reconnect throttle valve control module harness connector.
If wiring is OK:
Replace Motronic Engine Control Module (ECM) -J220- Page 01-57 .
Carry out adaptation of throttle valve control module to ECM Page 24-119 . [/align]
Old Jan 31, 2007 | 04:25 PM
southcoast's Avatar
where did you get that info? i cant see what is supposed to be in the boxes, looks like diagrams or pics. Thanks !!
liamol
B7 Models
Dec 5, 2011 03:41 PM
cardiffkid
Oct 13, 2008 12:52 PM
JohnnyS4
Oct 13, 2008 10:02 AM
adotjdot
Nov 16, 2007 04:48 PM
AudiTim
Aug 13, 2007 05:55 PM
