Faze bost gauge
who has a faze boost gauge, and how did you install it, i have mine mounted, wiring hooked up, but have not plumed the line i have sen people"T" off the FPR but the line supplied with the kitis too thin, it came with fittings and the instructions said there should be aplug on the manifold but i cannot see one.
and any one thinking of getting a faze air/fuel guage, don't bother, it dose not have a wide enough spectrum to give an accurate reading i am going to try and take mine back to get an oil pressure gauge.
any ways
like always
thanks for any help!
any ways
like always
you dont put the nylon line into the T. you put it in a tube similar to the vacuum tubing (any small rubber tubing will work) and then that connects it to the T. and you can place the T in either the line between the FPR and intake manifold, or (what i recommend) between the DV and intake manifold.
Russell2686
Jul 8, 2009 11:55 AM
slackerscott04
11
Feb 21, 2007 04:46 PM
