fellas i need your help again... thanx
Old Mar 23, 2005 | 10:55 AM
rnbguy's Avatar
Default RE: fellas i need your help again... thanx
okay sounds like a plan ill wake tomarrow give it a go before goin to work, and do the TBA too.. if there are any other suggestions that would be good thanx heaps
Old Mar 23, 2005 | 10:58 AM
Jestnomen's Avatar
6th Gear
ill keep searching for you today, i'll let you know if I find anything.
Old Mar 23, 2005 | 11:00 AM
rnbguy's Avatar
thats greatly appreciated, thanx heaps mate
Old Mar 23, 2005 | 03:34 PM
BFlan's Avatar
use some gumout fuel injector cleaner (a fuel additive). jest recommended it and it helped my car a ton. i got about 50+ miles per tank (and i still have another bottle to run through), and i noticed better throttle response when i really get on it.
btw, that knocking that you hear is probably just your valves getting pummelled by your pistons. but don't worry, it's normal.
Old Mar 23, 2005 | 03:43 PM
Jestnomen's Avatar
6th Gear
Sweet, you didn't tell me the gumout worked Brian. Glad to hear that!
Old Mar 23, 2005 | 03:54 PM
BFlan's Avatar
yup, just killed the first tank-full last night. i've never had any luck with additives in the past, but that stuff is great.
Old Mar 23, 2005 | 04:26 PM
CRAZYHAWK's Avatar
Could be a bad knock sensor.
Old Mar 23, 2005 | 09:38 PM
  #18
rnbguy's Avatar
ive tried fuel additives before, they help but not with the knocking... hmmm im gonna go disconnect battery now anyway...
Old Mar 26, 2005 | 02:36 PM
  #19
rnbguy's Avatar
okay i tried that, done nothing , it ran sooo smooth for like a day then went bak to rough, but now i get these codes
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
P0131 - 35-00 - -
16716 - Knock Sensor 2 (G66): Signal too Low
P0332 - 35-10 - - - Intermittent
16711 - Knock Sensor 1 (G61): Signal too Low
P0327 - 35-10 - - - Intermittent
i just installed the o2 sensor and know its 100% correctly installed so whats going on? is their a bad power supply somewhere? i know the 18010 error is because i disconnected the battery but whats all this signal too low business?
thanx again
Old Mar 27, 2005 | 07:12 AM
  #20
rnbguy's Avatar
pleaseeeeee helpppppp
what do i doo?
S4speedfreak
Dec 24, 2007 07:52 AM
mrd694
Dec 15, 2006 06:29 PM
trailerparkjesus
Aug 9, 2005 10:09 PM
