A few Maintance question**
Old Aug 27, 2007 | 06:33 PM
02B6's Avatar
Default A few Maintance question**
I wanted to change my spark plugs myself but i couldnt find out and specs on the #'s...I have checked the manual but nothing is mentioned.. It just tells you to go to the dealer. which equals $$...anybody have that info.. it is.. 2002 1.8t
Thanks in advance
Adam
Old Aug 27, 2007 | 06:38 PM
A4 Effort's Avatar
Default RE: A few Maintance question**
Although i have a B5, i run NGK Iridium IX in mine. Here's a link to the platinum plugs for your car on their site:
http://www.ngk.com/results_app.asp?AAIA=1379617
Old Aug 27, 2007 | 06:49 PM
02B6's Avatar
Thanks man!!
Old Aug 27, 2007 | 06:58 PM
02B6's Avatar
I also have another question...its kind of noob, but im not sure if i have hid in my b6..If i do i want to upgrade the bulb intensity.. ie 8000k etc...I believe my bulb size is H7.. can i just buy an 8000k set of H7 bulbs and plug n play?
Old Aug 28, 2007 | 12:02 AM
akielb's Avatar
if you have H7's then you don't have HID's - audi stock HID's are D2S bulbs. to upgrade order a kit off ebay from a user named "flashplus" this is VVME.com's ebay ID - they are very good and under $100 shipped. remember that anything over 6k and you'll loose light power - stock is 4300k and most suggest never going over 6500k
Old Aug 28, 2007 | 12:09 AM
Adam@mvp's Avatar
Also another thing to take into consideration, seen that you just threw out a number... "7000k". Do you know what or how its measured or if the higher or lower the number the better?
K means Kelvin that is how an HID is measured
HID means High Intensity Discharge
The higher the #k it is the more of a purple it gets and is not as condensed, more scattered.
The lower the number is usually better, a brighter white that is very concentrated and will hit a good amount of space depending on what brand you go with, quality etc.
Adam~
Old Aug 28, 2007 | 09:42 AM
ironman's Avatar
i believe he said 8000k which is a temp offered, and yes to teh VVME.com good price and good stuff
Old Aug 28, 2007 | 04:29 PM
kchao2000's Avatar
Yup... higher number of HID is just for the color. You will get more purple hue with higher number but you will lose the brightness. That means the light won't shoot very far.
Old Aug 28, 2007 | 08:10 PM
02B6's Avatar
thanks for all the imput. I do know how hids and the numbering works...how do i go about checking if i do have hids? I went to a link that just states different bulb sizes. I'm not sure exactly what I have.. Do i have to open the light fixture?
Old Aug 29, 2007 | 05:49 PM
02B6's Avatar
anyone?
