fit 19s on 3 inchs lower
Old Jun 3, 2007 | 08:20 PM
widlcats's Avatar
Default fit 19s on 3 inchs lower
can you fit 19 inch rims on a audi that is lowerd 3 inchs. i got 17 inchs right now and i want to go bigger. 19 inch would be sick but im guessing only 18s would fit. anyone know if they would?
Old Jun 3, 2007 | 08:22 PM
AteUrV8's Avatar
Default RE: fit 19s on 3 inchs lower
im assuming you have coilovers because thats the only thing that will drop it 3 inches, so get nineteens and adjust the coil's to the right height... its simple.
Old Jun 3, 2007 | 09:40 PM
headshok2002's Avatar
Uhh, 19" tires will have the same dimensions as 17" tires... so why would it make any difference? As long as you don't go too wide, or get the wrong offset... you'll be fine. A 225/45/17 tire will have the same outer dimensions as a 225/35/19. If you're concerned about rubbing, don't go wider than 8", and get an offset around 35.
MikeSpock/AWE
Apr 17, 2015 04:28 PM
Andrew/AWE
Feb 7, 2013 10:58 AM
cruciform
Oct 11, 2010 03:54 PM
wolfe2118
Jun 25, 2008 07:09 PM
EvilA4
Mar 13, 2006 06:39 PM
