Fitting a fridge / charger module
Guys,
I'm in the process of fitting a gizmo to charge a secondary battery and a fridge which I'm putting in the trunk of my Avant. I've had fun removing panels to run the cables from the engine compartment through the cabin and I've got one more wire to connect. The unit is activated whilst the ignition is on and the instructions say that I need to connect this last control wire to a wire which carries 12V when the ignition is on. Which one would be the simplist and / or safest?? I'd like to make the connection near the fuses if possible...
Thanks for your help
Irvin
Irvin
