FM reception problem
Old Nov 8, 2006 | 02:57 AM
dankhound's Avatar
Default RE: FM reception problem
Chicken. Balk balk balk. Ok maybe your right trim panels in audis can be a real pain. The one for the diversity box is pretty easy thou. You just pull. Start by the rear windshild and "gently" yank it out of the clips.
Old Nov 8, 2006 | 03:28 AM
Beer Mod's Avatar
Any fix for those of us that went with limo tint?
Old Nov 8, 2006 | 04:16 AM
Ford2Audi6's Avatar
I'm in the same boat with 15% on the rear window. Anything??
Old Nov 9, 2006 | 02:01 AM
dankhound's Avatar
External antenna. The brand of tint probably makes a difference. There has to be some metal in some tints that causes the reception issues. Because not every car with tints has issues.
Old Nov 9, 2006 | 02:57 PM
nmilner's Avatar
Apparently the small co-ax cable connector is broken and the garage wouldn't do any more testing until this was fixed. The bad thing was they couldn't just replace the connector - they said they had to replace the entire loom involving 4 hours of work taking the car to bits! Being an electronics engineer I wasn't going to accept this so located a replacement connector (I will tell the garage that you can actually buy replacement connectors!). But, I also noticed the mating half on the HU was also broken! So, I have decided to have a go at changing the connector on the HU and the co-ax cable to SMA (the current connectors are the cheaper SMB). I doubt very much this will fix the reception problems on FM but hopefully if it goes well the garage can have another go at diagnosing.
I'll have a look at the trim panel at the back window and have a gentle pull on it to see if it will come off as you say. If the diversity amp is behind there I might just get a replacement and bypass the garage all together.
Old Nov 12, 2006 | 12:50 PM
dankhound's Avatar
Its not really a gently pull. A quick yank does the trick thou. The clips are pretty tough. Just start at one end and work your way down.
Old Nov 12, 2006 | 02:01 PM
chaos92287's Avatar
ORIGINAL: Ford2Audi6
ya there is. you gota get a more expensive tint. they have a tint thats made out of a different material than the normal tint and isn't supposed to mess with the reception. i forget the name. i got it put on mine and i dont have any problems with reception
Old Nov 12, 2006 | 04:07 PM
  #18
Amze's Avatar
damn glad I read this, haven't tinted my car yet, now I know not to go overboard
Old Nov 12, 2006 | 04:19 PM
  #19
chaos92287's Avatar
or u can just shell out some more money and it wont be a problem. u can still see inside my car so when i go back home im changin the back window to 5% adding 5% on the sunroof and slightly tinting the front. i got 20% all the way around now but its just not dark enough for me. however i dont wana make it look illegal so hopefully only the back being 5% will help
Old Nov 12, 2006 | 04:27 PM
  #20
Lazer Viking's Avatar
i havent even listened to the radio in my car, so i really dont know how the reception is
