FMIC
Old Oct 21, 2007 | 11:28 PM
A4Boy90's Avatar
Member
Default FMIC
Quick new question didnt find anything on this either....
the piping to the FMIC 2.5.... 2.75 or 3" again witch one
Old Oct 21, 2007 | 11:36 PM
A4speed's Avatar
Default RE: FMIC
depends on your turbo setup.
if you have the stock k03 turbo then use 2.25
Old Oct 21, 2007 | 11:37 PM
The Russian's Avatar
Default RE: FMIC
what do you have under your hood? i got all stock motor and stock turbo with a chip, and i have 2.25" piping i'll put up some pics soon.
Old Oct 21, 2007 | 11:40 PM
cincyTT's Avatar
I'm make believe
Default RE: FMIC
2.25 will be good up to low 300whp
Old Oct 22, 2007 | 12:21 AM
A4Boy90's Avatar
Member
Default RE: FMIC
yeah i'm all stock.. just getting good deals on some things so im gonna buy them and when i get all the things i want i will install them.... so 2.25 i wanna go BT but i need a different A4 unless i decide to put time into converting mine to a manual dont know yet... anyone know where to have my ECU chipped i cant find one already chipped for an auto... what would be the difference with a 2.25 and a 2.5
Old Oct 22, 2007 | 12:36 AM
A4speed's Avatar
Default RE: FMIC
on your stock turbo you would lose boost if you went 2.5, 2.25 will maintain the boost as well as have added performance.
go to goapr.com and giacusa.com for dealers close to you (for chip)
Old Oct 22, 2007 | 05:02 AM
david9999's Avatar
Default RE: FMIC
Larger diameter tubing wont cause you to loose boost. May cauase an imperceptible increase in turbo lag, but the pressure at the engine will not decrease.
Old Oct 22, 2007 | 09:27 AM
EliteTuning1's Avatar
Default RE: FMIC
i lost 7psi when i went with 2.5" piping so now im switching to 2"
Old Oct 22, 2007 | 09:44 AM
The Bishop's Avatar
Default RE: FMIC
Plus the bigger the intercooler/piping, the harder it will be to fit behind the bumper.
Old Oct 22, 2007 | 11:27 AM
A4Boy90's Avatar
Member
Default RE: FMIC
ok so if i get a ko4 turbo i'll still be fine with the 2.25 im sure i could go look for this answer but to lazy plus im at school and have no time is it even worth buying the ko4... yeah i like EliteTuning1's FMIC setup.. im goin for that look
