fmic piping size!?
Old Oct 29, 2007 | 09:10 AM
comfort_racing's Avatar
Default fmic piping size!?
quick question i have a fmic on my car that i did using a diy article on the forum in which the guy used a 2.5" inlet/out fmic, and on the turbo side used 2" piping and on the outlet side used 2.5" piping. i have run it for awhile with no complaints, but i noticed all the kits run either 2" or 2.25" ic piping on their kits.
QUESTION:
Is the 2.5" piping helping or hurting my performance? should i make it all 2.5" or 2" or keep it the way it is now?
Old Oct 29, 2007 | 09:12 AM
onepoint8tee's Avatar
Default RE: fmic piping size!?
If you dont have pressure drop, dont worry about it.
Old Oct 29, 2007 | 09:18 AM
as in boost pressure? it doesnt appear to be dropping except of course the bleed off from a leak i have to find. does the 2" on the one side help or can i swap it all to 2.5" up to the inlet piping?
Old Oct 29, 2007 | 09:20 AM
With a k03/04, the closer to stock dimension i/c piping the better.
Old Oct 29, 2007 | 09:34 AM
is that due to a spooling issue?
Old Oct 29, 2007 | 09:52 AM
Itsdue to a need for minimalvolume of space to maintain aconstant pressure that a turbo the size of your fist is blowing.
Old Oct 29, 2007 | 10:14 AM
gotcha, thanks for the advice.
Old Oct 29, 2007 | 01:50 PM
cincyTT's Avatar
I'm make believe
2.25" all around would be best. Elitetuning or something like that has 2.5" and he has a great deal of pressure drop and im sure his core is a little to large also.
Old Oct 29, 2007 | 03:52 PM
EliteTuning1's Avatar
yeah i had 2.5 piping and was at 11 psi. i just put on 2" piping and now im still at 11. im checking for boost leaks and i think my mbc is faulty cause no matter what i do the boost never changes.
Old Oct 30, 2007 | 08:49 AM
see i have run this setup for awhile and since i run stock software i was always at 9.5 psi i always had leak issues too and elbows popping off. then i upgraded the couplers and put t-bolts on. no pop offs but like a week ago it would hit 9.5 then slowly bleed down to 7 or 8. now it wont go any higher then 7 or 8. confusing...any ideas?
Does9.5 psisound like i had a huge pressure drop. maybe a 1/2 psi not sure what stock psi is exactly, i heard like 10 psi. i have dumped a bunch of money in this diy so far and the wife is gonna kill me soon. switching to 2" on both sides or 2.25 would be another 100 - 200 dollars. good couplers are expensive!
