FMIC question
would this FMIC be good for my 2004 A4 1.8T
Brand New...100% Aluminum, hand welded, constructed with a tube and fin design. 20.5x6x2 3/8 Polished finish intercooler. Perfect for your next turbo project or upgrade. Buy direct from importer and save BIG.
Good for up to 400bhp. all our intercooler has been tested to withstand more then 80psi pressure and it has very small pressure drop across the end tanks, at 15psi inlet the out let has 14.8psi that means it has only 0.2 psi pressure drop ,compare to many other intercoolers it is an excellent figure (some intercooler has 1-2psi pressure drop) also at the same condition, the temperature has drop from 120 degree to 28 degree ( and it is an excellent figure for efficiency)
[size=2]Core Length : 20.5"
Core Height: 6"
Core Thickness: 2 3/8"
Inlet Size: 2.75"
Outlet Size: 2.75"
End to End" Length: 28"
[sm=feedback.gif]
Core Height: 6"
Inlet Size: 2.75"
Outlet Size: 2.75"
[sm=feedback.gif]
nope, sounds like one of the cheap ebay ones with shitty internal fin structure. Also there is no reason a properly designed intercooler would have an inlet or even an outlet thats 2.75" That ic couldnt possible flow enough to warrant the use of a ic piping that big
