Fog Lights
Old May 30, 2006 | 11:08 PM
robfresh's Avatar
Default Fog Lights
Is there a replacement grille where the fog lights go or do you cut out the grille yourself. How would I connect to my fog lights which are inside the headlamps.
Old May 31, 2006 | 01:35 AM
Trey25's Avatar
Default RE: Fog Lights
I take it you want foglights like 00+ models, so do I...well from what I heard the 00+ grilles can't fit on a 98, but I'm getting two from the junkyard just to find out for myself. What you can do is get this http://www.lltek.com/fog.htm. Buy the whole kit or just the grilles and then get your own fogs. To wire independent fogs splice/soder to the green/white wire off the harness (thats your headlight fogs) and run them from there, then hook up your ground to the frame. If you can't find the fog wire use a multimeter and check at the connection. If I lost you have someone electrically inclined do the wiring lol
Old May 31, 2006 | 10:37 PM
robfresh's Avatar
Thanks I'm going to check that out. I'm somewhat inclined in that area, but I have had trouble in the past with audi electrical problems. Most of them were from what someone else did wrong. Have you seen another car that has fog lights done like that, and have they had any problems?
Old Jun 1, 2006 | 01:06 AM
Trey25's Avatar
I've only seen one and hes acetrebo. here are his pics https://www.audiforums.com/albumphot...Type=1&apage=1
Old Jun 2, 2006 | 12:19 AM
robfresh's Avatar
Wow! He did a nice job. Thats how I want mine to look. I like the chrome exhaust too. I'm going to send my pictures when I'm done with my car. I just hope it looks just as good. Thanks for those pics.
nize
Jun 21, 2013 01:16 PM
mypreludeisred
Aug 9, 2006 11:08 PM
