fog lights....
Old Apr 10, 2007 | 05:17 PM
njm23's Avatar
Default fog lights....
So yeah, I never even bothered to put my fog lights on, until the other day. And the button wouldn't light up, so I knew something was wrong..I checked the fuse panel and of course, the fuse for the fogs was missing..Put a new fuse in and now atleast the light comes on but neither of my fog lights come on!..I was just outside and pulled out the drivers side light, the wire was there, was plugged in. Bulb seems to be ok..ANyone have any suggestions?? seems weird that they both would not work..
Old Apr 10, 2007 | 05:26 PM
Audi_Skydiver's Avatar
Default RE: fog lights....
Get a volt meter and check the wires with the switch turned on.
Josh
Old Apr 10, 2007 | 05:27 PM
CRAZYHAWK's Avatar
Fog lights work only, with low beams on.
Old Apr 10, 2007 | 05:31 PM
SacTown_Vlad's Avatar
ORIGINAL: CRAZYHAWK
NO, atleast not my audi, i use to drive with only my fog lights on
Old Apr 10, 2007 | 05:33 PM
^ yours is different then. Mine only work with the low beams on as well.
Josh
Old Apr 10, 2007 | 06:02 PM
njm23's Avatar
Had power, blew a fuse..replaced it..no more power (i am retarded lol) This is only my drivers side I am checking by the way, I have no time to do passenger side off to work..Any ideas? It was receieving power..O yeah-i checked for power where it plugs into the fog light from the car-if that helps.
Old Apr 10, 2007 | 06:25 PM
New bulbs then.
Pull one of them out of your headlights (they are the same unless you have the HID lights but then just take the High-Beam bulb out.) And put it in your fog lights. See if it comes on.
Josh
Old Apr 10, 2007 | 07:28 PM
Lopster99's Avatar
If your foglights work with out any lights being on then you have the "euro switch" i bought one when i had my GTi 20 anniv
Old Apr 10, 2007 | 07:39 PM
PandaXpress's Avatar
ORIGINAL: CRAZYHAWK
i was thinkin that
and do u kno how to turn them on u do kno u gotta pull the switch out rite
nize
Jun 21, 2013 01:16 PM
mypreludeisred
Aug 9, 2006 11:08 PM
