fog lights and others
Old Apr 27, 2005 | 01:01 PM
cdnskier's Avatar
Default fog lights and others
just a couple of quick questions:
i've gotta 2000 1.8, one of the front fog lights are out in the front and one in the back... should i change both front ones? how do i get at them? and does anyone know the bulb type or size i need for those... its been raining lately and haven't had the chance to climb under the car...
Old Apr 27, 2005 | 01:22 PM
Jestnomen's Avatar
6th Gear
Default RE: fog lights and others
To remove the lights: pull the plastic surround off, it just tugs off. Remove the 3 screws. The light will pull out now. Rotate the back cover off. Inside will be a H7 bulb you need to replace. It's pretty easy all in all. Changing both is up to you, but not really needed.
Old Apr 27, 2005 | 01:26 PM
cdnskier's Avatar
thanks man, the sun just popped out now, gonna try it...
Old Apr 27, 2005 | 01:52 PM
cdnskier's Avatar
just tried getting at them... did u mean that plastic covering the fog light or something else... i tugged at it and it stayed on, didn't wanna pry too hard and rip something off...
so its just that little plastic cover actually around the fog light?
Old Apr 27, 2005 | 02:11 PM
brrman's Avatar
here dude
http://www.europeanspeed.com/fogs.htm
Old Apr 27, 2005 | 05:54 PM
cukilo's Avatar
Hey how do you install aftermarket forg lights on a B5 that didnt come with them originally? Do they come with fogs at all? I mean my year at least the 97?
Old Apr 27, 2005 | 09:57 PM
cdnskier's Avatar
thanks dude, appreciate it... made things a lot easier...
i ended up buying two new bulbs and now it seems like ones brighter then the other... maybe i'll just wait till night time to make the decision... either way
thanks man
cheers
Old Apr 27, 2005 | 10:11 PM
BFlan2001's Avatar
ORIGINAL: cukilo
the fogs were integrated in the headlights until 99.5, you can add lower fogs, but you have to make your own brackets, i've heard it's not very difficult
nize
Jun 21, 2013 01:16 PM
mypreludeisred
Aug 9, 2006 11:08 PM
