Fuel Pressure Regulator
Old Nov 3, 2007 | 02:53 PM
MasterV's Avatar
Default Fuel Pressure Regulator
If I install a K04 and get a GIAC chip will I need to upgrade my Fuel Pressure Regulator?
Old Nov 3, 2007 | 03:05 PM
chaos92287's Avatar
Default RE: Fuel Pressure Regulator
GIAC's programming uses a 5 bar fpr, but you might as well just get an adjustable one since most 5 bar fpr's out there aren't "true" 5 bar fpr's, but stock one's remodified.
Old Nov 3, 2007 | 03:06 PM
chaos92287's Avatar
just to make sure, your talking about the e05 file not one of the aggressive files right?
Old Nov 3, 2007 | 03:18 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: chaos92287
the e05? What another pos
Old Nov 3, 2007 | 03:21 PM
chaos92287's Avatar
e05 is the name of the basic k04 file from GIAC
Old Nov 3, 2007 | 03:27 PM
MasterV's Avatar
Can I get an agressive file with my tranny?
Old Nov 3, 2007 | 03:28 PM
chaos92287's Avatar
yup
Old Nov 3, 2007 | 03:34 PM
MasterV's Avatar
whats the most aggresive file I can get and whats the HP and Torque rating on it?
Old Nov 3, 2007 | 03:39 PM
chaos92287's Avatar
there is only 1 agressive file you can use. GIAC offers 3, pc-16 for pre-00, j31 for 00, and hammer for 01. so you would get j31, which happens to put out the best numbers out of the 3. you should get around 250-270 hp and ~300ft lbs of tq depending on supporting mods
Old Nov 3, 2007 | 03:43 PM
cincyTT's Avatar
I'm make believe
You sure about that? That is a e05 which is a direct swap for a ko3 and is bigger than a ko4-015 (just wheel size). The reason its probably "less agressive" is because the shaft on the e05 wasnt thick enough and running it over 17psi could snap the shaft.
