fuel pump install
Old Feb 3, 2006 | 05:41 PM
goldenchild's Avatar
Default fuel pump install
does anyone know how to get the pump out of the things its in. ive never seen a pump held in like this. damn germans
Old Feb 3, 2006 | 05:46 PM
techbod's Avatar
Default RE: fuel pump install
what car is it/engine size/age??
Old Feb 3, 2006 | 05:59 PM
01 a4 1.8t im puttin in a walbro and cant figure out how to get it out
Old Feb 3, 2006 | 06:08 PM
quattrosedan's Avatar
the walbro should replace the pump and the whole plastic housing around it.
Old Feb 3, 2006 | 06:10 PM
techbod's Avatar
fuel pump in tank access gained under rear seat or trunk area, there is a plate covering the pump with 3 hex screws remove that and you will see the large screw type plastic ring holding the pump in ( be careful when removing the flow pipes as the are easily broken the pipes are heat shrink type) not a nice job
Old Feb 3, 2006 | 06:19 PM
techbod's Avatar
the fuel pipes are going to be the biggest problem you can heat the ends with a hair drier to aid removal, I don't know of the walbro pump but the standard one has to be jiggled out because of the fuel level float which extends into the tank
Old Feb 3, 2006 | 07:06 PM
well i just found out how to do it and there is alot more involved then what u r describin
http://forums.audiworld.com/performa...gs/44541.phtml
Old Feb 3, 2006 | 07:14 PM
techbod's Avatar
simple job your replacing the pump only lol, I do hope that guy isnt useing his audio system while doing the job ( car-boom )
Old Feb 3, 2006 | 07:24 PM
ya right this damn thing is held in there fort knox on lock. im about to break the housing out of it bc its pissing me off. thats how i do things if it doesnt want to come out, off, or in ill beat it to do what i want...haha
Old Feb 3, 2006 | 07:49 PM
techbod's Avatar
its the fuel level sender float its a pig to get it right you just have to have patience then get the hammer lol take your time
