Fuse troubles
ok so on my trip back from south fl. i stopped at a rest stop, and when i got back in the car i went to turn on my headlights and they wouldn't turn on. the yellow corner lights work and if i pull back on the headlight stalk my high beams work but they piss off a lot of people while driving[8D] i checked the fuse box but they all seem to be fine. isn't there antoher set of fuses? where can i locate them and does anyone know which fuse would be causing this? o and the middle little computer on the dash is out too, so im guessing its the same fuse. its a 98 1.8TQM btw
RE: Fuse troubles
cant see any others
[IMG]local://upfiles/12092/C16E644689EB47AE9E24143D5864CCEB.jpg[/IMG] |
RE: Fuse troubles
Could be a bad bulb, but seems kind of strange for both of them to go at the same time.
RE: Fuse troubles
ya i checked all those but aren't there a set of bigger fuses under the dash or sumthin? those got wet a while back and caused my secondary fan to go out so im assuming the same happened with another fuse
RE: Fuse troubles
if it was a bad bulb wouldn't the high beams also not work?
RE: Fuse troubles
[IMG]local://upfiles/12092/EB0F6FCEAB10499F9C8A3A4461282A47.jpg[/IMG] |
RE: Fuse troubles
ORIGINAL: chaos92287 if it was a bad bulb wouldn't the high beams also not work? I can check for you when I get home, I'll look it up in the Haynes and look at my headlamps. Mines a 97 1.8 so we should be the same. Still, both sides going at the same time sounds like some kind of relay. I'll check back later, if no one has answered it for you I should be able to help more once I get to the manual. |
RE: Fuse troubles
ooh ya thats what i was looking for Dave. do you know how to get to those fuses?
RE: Fuse troubles
#3 fuse/relay plate
[IMG]local://upfiles/12092/1EEFE77B2EFF478B922AA1D571D2ACF4.jpg[/IMG] |
RE: Fuse troubles
if its left hand drive they might be on the other side but not sure;)
