gauge cluster lights
Old Jul 26, 2006 | 12:40 PM
tbehling's Avatar
Default gauge cluster lights
all of my gauge cluster lights are off on my 96 a4, i checked all the fuses, anyone have any ideas?
could all the bulbs go out at once?
could it be the dimmer switch?
sucks driving at night, i have to guess how fast i am going.
if i can fix the problem i was thinking about just ordering indiglo gauge faces
Old Jul 26, 2006 | 03:18 PM
techbod's Avatar
Default RE: gauge cluster lights
probably the dimmer switch or a bad ground on the dash
Old Jul 26, 2006 | 07:54 PM
wood_e's Avatar
probably the dimmer. Mine were off too and I poked around for like 10 minutes... the dimmer was set on the lowest setting. I cranked it up and it was fine.
Old Jul 26, 2006 | 09:41 PM
tbehling's Avatar
definatly not the dimmer, im not even getting power to the fuse block for the #5 fuse wich is the cluster illumination, so.. im trying to dig up some wiring diagrams online to track it down. As far as i know if goes from battery through the relay cluster to the fuse box and so on.. so theres gotta be a problem with a relay right?
Old Jul 27, 2006 | 12:07 PM
tbehling's Avatar
lil help
SirAiden
Jun 1, 2013 10:05 AM
flynnr
Nov 24, 2008 05:13 PM
chloechavis
Aug 15, 2007 04:03 PM
Spdrcr7882
Oct 2, 2006 08:07 PM
