GFB BOV questions.
Old Sep 7, 2004 | 04:13 PM
EvilA4's Avatar
Default GFB BOV questions.
When I get that CHIP (if I do) I would want to accompany it with a GFB Hybrid BOV. The hybrid is split 50/50; 50% recirculates, 50% is vented into the atmosphere. People say BOV's cause the check engine light to come on and backfiring... GFB claims they have fixed this problem. I dunno how many of you have BOV's.. maybe you can recommend something or if you have GFB, tell your story about it.
Also, I have no clue how to install the lil guy. Could someone give me an idea where the stock valve is?
Old Sep 7, 2004 | 04:25 PM
ImolaS4's Avatar
Default RE: GFB BOV questions.
OK... you need to search the archives on this before you get flamed. The BOV vs DV argument is well documented. There is a diagram of the DV location that I posted in one of the threads, too.
The GFB BOV is an unorthodox and interesting idea, but the manufacturer does not prove scientifically that the unit does a true 50/50 split with recirc and vented air. Furthermore, there is no evidence that the recirculated air is proper for the MAF readings. Many of us are very skeptical about this issue. There is a greater chance that a CEL and damage to components is inevitable - it may be delayed from what a regular BOV might cause, but it is inevitable.
Old Sep 7, 2004 | 04:27 PM
ImolaS4's Avatar
It's also an obnoxiously overpriced item!
Old Sep 7, 2004 | 06:09 PM
shon's Avatar
well you can get one for about the same as a billet bpv if you look on ebay.
also, consider this, if i get a neuspeed chip which is known to run the engine on the lean side (for engine longevity) and i get a hybrid valve (which run the engine rich) wouldnt the side effects be minimal?
wouldnt the 2 somewhat cancel eachother out?
Old Sep 7, 2004 | 11:07 PM
blades's Avatar
Member
How does running the engine on the lean side IMPROVE engine longevity?? Where I come from (homebrew turbo setup on a 2000 S-10 pickup), running lean is suicide for the engine. Of course that particular engine was never meant for turbocharging in the first place, but I was always under the impression that rich was better than lean.
Old Sep 7, 2004 | 11:18 PM
shon's Avatar
pouring unspent gas through your exhaust is worse than unspent air.
extra air would be much better than extra fuel... on said exhaust components such as the cats...
Old Sep 7, 2004 | 11:22 PM
blades's Avatar
Member
Yeah, that makes sense as far as the exhaust goes, but isn't there a concern of increased heat in the engine from running lean? I had my S-10 running fairly fat to help keep engine temps down, in addition to a cooler t-stat.
Old Sep 8, 2004 | 01:54 AM
David_K's Avatar
If your going to intentionally run lean for performance purposes make sure you go with hotter plugs.
Old Apr 2, 2007 | 04:37 AM
easter's Avatar
I had a GFB Valve on my 1.8t for about 6 months, I absulutly loved it the sound was just perfect not overbearing or underherd! I left it set at 50/50 and never had a problem with my check light or backfire! there is no performace gain at all but for me was totaly worth getting! Im planning to get a s4 with 2 GFB valves installed i herd one with full blowoff and it sounded like a freken jet gonig bye thou i will only keep it on 50/50 but should be just enough! for me hope this helps.
-Audi for Life
Old Apr 2, 2007 | 04:41 AM
Audi_Skydiver's Avatar
Same Guy maybe saying that???? IDK
Josh
