Give advice on a Cool Air Intake PLZ!!!
Old Sep 9, 2006 | 01:57 AM
CluTcH/B5's Avatar
Default RE: Give advice on a Cool Air Intake PLZ!!!
what i did was cut lower on the air box.
I didn't drill some many holes, and put the towards the top of the fender liner. think that will help+ the screen.
Old Sep 9, 2006 | 02:25 AM
Dimad13's Avatar
[img=http://img118.imageshack.us/img118/3875/untitledci1.th.png]
Is it me or is there a big hole between the air box and the fender. Wouldn't that suck the hot air from the engine in? When I do mine I'll try to leave that part alone so that the box presses perfectly against the fender.
Old Sep 9, 2006 | 02:36 AM
BadLuckAudi's Avatar
you need to seal that gap with foam, and second theres like no way your gunna get water ing there unless you drive in to a river and then your gunna have bigger problems than a little bit of water, mine is entirely cut out down there and has no screen, and have had absolutly no problem with water and i was driving in 2 feet of snow all winter and even went through some huge puddles with no probs
ORIGINAL: Dimad13
Old Sep 9, 2006 | 02:40 AM
Dimad13's Avatar
Sounds good. How bout the MAF, do I need a new one because I remember reading somewhere that it can **** up ur car with a new Intake.
Old Sep 9, 2006 | 02:44 AM
you will only **** the maf if you over oil the K&N
Old Sep 9, 2006 | 03:01 AM
Dimad13's Avatar
alright sounds good. Ill have to test it out tomorrow. I'll see what happens. Thanx for the help.
Old Sep 9, 2006 | 03:08 AM
wood_e's Avatar
If you over oil the K&N (and from the factory, they ARE over oiled) you can clean the MAF with electronics cleaner.
Old Sep 9, 2006 | 03:55 AM
  #18
ADubyaD's Avatar
SoCal Crew Member
i did that airbox mod as well, it sounds badass, after that i threw on a cone and ditched the airbox, then made my own little ghetto heatshield, it sounds about the same and maybe pulls a wee bit better,
Old Sep 9, 2006 | 04:01 AM
  #19
Dimad13's Avatar
Can I see a picture plz?
Old Sep 9, 2006 | 06:00 AM
  #20
Dj Spiel's Avatar
AS a previos Owner of a 96 a4 i can tell you.... an intake will only show gains in 1st gear. and really not even that much
https://www.audiforums.com/photo.asp...ype=6&apage=1#
