going to audi
Old Apr 26, 2004 | 03:03 PM
Maverick's Avatar
Default going to audi
sounds like i might need new brake pads since im getting squeeking when coming to slow stops/stops.</P>
and im bringing it to the dealer for 35k maintenance</P>
what kinda price tag am i looking at here? </P>
</P>
I also have an issue where the car seems to idle rough, sounds like a diesel engine, which i assume is not normal.. and recently... i started it up and it when i put it in drive it sounded like it was going to stall for a sec....
also sometimes when im driving and accelerate/decelerate i get not a grinding noise, but a churning type noise...</P>
these issues should be covered under my warranty</P>
i just dont want to walk in with price shock.. and just get some of your opinions on the issues im hearing/seeing</P>
</P>
thanks!
</P>
</P>
</P>
Old Apr 26, 2004 | 04:30 PM
Jestnomen's Avatar
6th Gear
could be youridle control valve possibly needs cleaned or replaced.
Old Apr 27, 2004 | 03:55 AM
brrman's Avatar
Sounds like it could be a belt flapping around. Last time my car sounded like a diesel the timing tensioner had failed and the belt was just flapping around. Luckily the belt did not slip or shred before I discovered the problem and changed it. Might also be bad lifters causing the sound.
As to the idle, possibly a vacuum leak, bad maf, bad icv, failing ignition amplifier, dirty plugs... i could go on and on...
You are on 35k? You should be under warranty then right?
Old Apr 27, 2004 | 09:33 AM
Maverick's Avatar
yes i am, thank god.. and i bought the car certified pre-owned, so the audi dealer i bought it from told me i had a 2 year bumper to bumper or 50k miles, whatever comes first.
i recently had my turbo replaced, so I am taking in may 3rd ill see what happens, lol
thanks for the info everyone
Old Apr 27, 2004 | 07:36 PM
active1331's Avatar
got to love those warrinties
Old May 4, 2004 | 02:28 AM
Maverick's Avatar
update....
just got a call back from audi
the noise i heard at idle, almost like a diesel engine, they told me i needed a new water pump, one of the seals could have been making that noise.
here is the kicker.
they audi certified pre-owned warranty covers the water pump, but not the thermostat they had to put in, so now i gotta see how much that is going to cost.
Old May 4, 2004 | 04:12 AM
brrman's Avatar
thermostat should cost no more than $25-$35 bucks (www.ecstuning.com) - maybe more at the dealer. And don't let them charge you out the *** for labor on the thermo! There is no extra labor involved cuz the thermostat is housed IN the waterpump!
Old May 4, 2004 | 11:07 AM
Maverick's Avatar
thanks brrman</P>
</P>
i will be calling today to find out the price</P>
</P>
</P>
