Going rate for 80K service...?
Old Feb 10, 2005 | 05:40 PM
BlueLord's Avatar
Default Going rate for 80K service...?
My First Post:
I have a new (to me) 2001 A4 1.8T Quattro and it has about 78k on it. Can you please let me know what the going rate is for a 80K service. I was quoted $615 by a dealership here in Tampa. Also if anybody knows a good shop in the Tampa area that I should check out please let me know.
One of the reasons that I want to have the service done is because I have a strange vibration or something on the right front. Feels like maybe a bent rim but doesn't. I can feel it more at low speeds and breaking/slowing than I can at high speeds. Let me know if there is anything I can check for before I get ripped off at the dealership. I am a bit upset because I didn't feel this when I test drove it and now is seems very apparent.
I will have more questions in the next couple of days. I trolled around for a few weeks while looking to get this car but now I have it and I will be actually posting.
-Pete
Old Feb 10, 2005 | 07:07 PM
CRAZYHAWK's Avatar
Default RE: Going rate for 80K service...?
You'll probably get an expensive oil change. They should replace the spark plugs, pollen filter , air cleaner , ribbed belt and V-belt.
They'll do the timing belt at 90K mi. Good luck finding an independent shop. Ask people you know with German cars where they get service.
Old Feb 10, 2005 | 07:35 PM
Jestnomen's Avatar
6th Gear
I would find an independant shop to handle your service. You are goign to get ripped off at the stealership.
Old Feb 10, 2005 | 09:01 PM
CRAZYHAWK's Avatar
Well said Jest.
Old Feb 10, 2005 | 09:59 PM
BlueLord's Avatar
I know that is what I was thinking. Anybody know a good independent shop in the Tampa area?
Thanks,
Pete
Old Feb 10, 2005 | 11:48 PM
Jestnomen's Avatar
6th Gear
Here's a few that others have recommended from the area:
Cars and Concepts
Eurotech Racing
Old Feb 11, 2005 | 12:22 AM
John_E's Avatar
Another option is to DIY whatever you feel comfortable doing yourself. For example, OEM NGK spark plugs for the 1.8T engine are $11 each at RockAuto.com, but the going parts-and-labor rate for spark plug replacement at a dealership is about $120. Similarly, 4.5 qts. of Mobil 1 = $18 on sale, and you can buy the larger VW 068-115-561B oil filter or its Mann or Mahle equivalent for $7.50, giving you a proper oil change for the cost of a dino schlock job at Jiffy-Lube. The cabin air filter is a trivial DIY and another chance to save money, and the engine air filter is not that tough, either.
Old Feb 11, 2005 | 12:32 AM
IWantAnA4's Avatar
i thought scheduled maintenance was free of charge while under warranty??
Old Feb 11, 2005 | 08:05 PM
CRAZYHAWK's Avatar
The warranty ends at 50K mi.
Old Feb 12, 2005 | 12:34 AM
IWantAnA4's Avatar
thankfully i have the extended warranty since i bought my a4 certified pre-owned
jorgecol77
Feb 19, 2013 10:42 AM
audiTTforme
Mar 10, 2011 09:31 PM
michaelmccormack
Jun 25, 2009 10:41 AM
graviton
Feb 20, 2008 06:01 AM
BlueLord
Feb 21, 2005 05:02 PM
