good/bad
Old Nov 28, 2006 | 06:58 PM
new2me's Avatar
Default good/bad
Well put in a boost gauge today and went for a spin. When i drop the hammer i spike 18-20psi then drop down to 10psi. (thinking boost leak) Problem is I dont know what kind of software this car has if any. I assume its chipped since its spiking 20psi. & holding 10psi. I tapped the foot long vac line that goes from under the intake plenum to the side (front side of motor) of the intake plenum.
The guy I bought it from didn't know much about the car other than its always had synthetic oil, upgraded cluch & has the sport package.
Over time i discovered that it has a K&N panel filter and AWE trans bar.
Old Nov 28, 2006 | 07:26 PM
new2me's Avatar
Default RE: good/bad
Oh all i can tell about the DV is that its a Bosch.
Can anyone give me any idea's to what's going on.
Old Nov 28, 2006 | 07:41 PM
BaconBait's Avatar
Is it still hitting 20 psi?or is it stuck at 10 psi now?
Old Nov 28, 2006 | 07:54 PM
new2me's Avatar
At idle im at 18psi vac when i punch the gas i spike 20psi then drop to 10psi if i keep the gas to the floor.
I took the car for about a 4 mile drive. 2 miles to the store and 2 back and the same readings both ways
Old Nov 28, 2006 | 07:56 PM
BaconBait's Avatar
just caught your last edit
Old Nov 28, 2006 | 07:59 PM
BaconBait's Avatar
It could be your N75 catching up to the boost spikes. You might want to try a mbc. A leaking dv wouldn't hold 20psi.
Old Nov 28, 2006 | 08:03 PM
new2me's Avatar
Well i almost bought a forge dv and n75j should i wait?
Could this be a leak in the air line?
What's a good price for the mbc?
Old Nov 28, 2006 | 08:15 PM
BaconBait's Avatar
Doubt it's a leak. You wouldn't peak off like that if it was a leak. You're going to need a dv with that much boost.
edit- Can you hear any leaks? Like when the spike goes away?
Old Nov 28, 2006 | 08:41 PM
new2me's Avatar
It's really loud when im under boost but i dont hear it when im just crusin. My air box is "stock" and it sounds like the noise is on my side of the car not the passenger side.
Old Nov 28, 2006 | 08:47 PM
BaconBait's Avatar
Does it do it when you rev the motor? Have a friend gas it while you peek under the hood.
