Is this a good intake?
Old Feb 14, 2005 | 03:35 AM
aaronamericahall's Avatar
Default RE: Is this a good intake?
ORIGINAL: Jestnomen
ORIGINAL: aaronamericahall
I think its worth it, it will be alot better than stock
CAI are not a LOT better than stock if any at all. OEM audi airboxes flow well to begin with.
trust me from experience dude it will be better than stock you will feel the difference but not a major difference even if you just throw on a cone filter you will notice the difference. the stock box is so restrictive if you guys would open your hood and take the box apart you will see and not only that why would a company make a intake for the car and the stock is supposed to be better
Old Feb 14, 2005 | 03:38 AM
oh you will also hear the intake sucking in that air it sounds so nice
Old Feb 14, 2005 | 04:37 AM
jhchow's Avatar
can i get any feedback on this intake here?
http://www.boostedtech.com/audi_02a4.asp
i am thinking about purchasing an intake
but i have no clue where to start from....
thank in advance.
Old Feb 14, 2005 | 05:17 AM
Transverse's Avatar
**Our cold-air intakes are designed for dry weather conditions only and should not be used in any wet climates or on any wet roads or highways. Failure to comply with this warning may cause water to be absorbed into the engine through the filter, causing serious damage to your motor. Boosted Technology, Inc. assumes no liability for damages to your motor due to water entering your engine through our cold-air intakes. -- boostedtech.com
Hmm...so..when it rains..don't drive?
-T
Old Feb 14, 2005 | 09:51 AM
david9999's Avatar
Right, I bought a quattro so I could only drive when it is dry.
Besides, I drive for 3 hours a day. I dont want to hear my car sucking wind all day...
Old Feb 14, 2005 | 07:15 PM
turbo's Avatar
looks like someone bought this $29 pice of crap, and is standing there ground with this intake.
no matter how you look at it ,this thing is junk, It may however grab the eye of a honda owner because it is shiney.
I guess if you are looking for something flashey with no regard of quality then this is for you.
Just keep in mind you own an audi.
Old Feb 14, 2005 | 09:49 PM
[quote]ORIGINAL: Transverse
Thats if you are using a Cold Air Intake with out the bypass valve, that intake you guys are looking at on ebay is a short ram intake. A Cold air intake is a intake that goes down to the bottom of the car usually towards the front bottom bumper which will suck in water with out the bypass valve since its so close to the ground
Old Feb 14, 2005 | 10:00 PM
  #18
ORIGINAL: jhchow
thank in advance.
thats nice they even have a dyno compared to stock with a K&N fiter. I rest my case
Old Feb 17, 2005 | 11:00 PM
  #19
apg96's Avatar
does anyone know of a good CAI for my car (w/ bypass if possible)?
Old Feb 18, 2005 | 02:11 AM
  #20
apg96's Avatar
What is the difference between this CAI (Evo) and this one from above (actually this one and i might put on a heat shiled this one?
On the bootom one they have a housing over the air intake (where it enters the engine) that says V6. Where can i get one of those if i buy this?
