great...puttering like a mofo
Old Sep 26, 2007 | 01:35 AM
zat0rsk1's Avatar
Default great...puttering like a ****
just great, on my way back from work , car hesitates like a mother phuqer. and putts real bad in neutral or at a stop. jesus christ man. car sounds like an STI now. gonna go to autozone and get the codes, hopefully it aint nothing big. lol
Old Sep 26, 2007 | 01:52 AM
Belligerenceâ„¢'s Avatar
Default RE: great...puttering like a ****
coilpack(s). or ICM.
Old Sep 26, 2007 | 08:55 AM
akielb's Avatar
Do you have a CEL - or more importantly a blinking CEL? - if its blinking the +1 for ^
Old Sep 26, 2007 | 04:09 PM
zat0rsk1's Avatar
blinking CEL. i just got the codes pulled from autozone. man those guys are dumb , they have no idea wut their talking about.
guy said sumtin about cylinder 1 and 4 are misfiring..... wut the fugg !!!
p1338
p0301
p0304
p0116
Old Sep 26, 2007 | 04:15 PM
akielb's Avatar
ORIGINAL: zat0rsk1
p1338
Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+
p0301
Cyl.1 Misfire Detected
p0304
Cyl.4 Misfire Detected
p0116
Engine Coolant Temp.Circ Range/Performanc
Those don't look good - for some stupid reason the coolant temp sensor can screw with all kinds of stuff. I would be afraid of the cam position code
Old Sep 26, 2007 | 04:19 PM
zat0rsk1's Avatar
jesus christ...... i can not bring it to any mechanics around here , they are total ripoffs. and i have about 100 bucks in my wallet lol. is there anyway i can mabe check the spark plugs and coil packs to see if their the culprit, pos cam sensor , i already had that , thats being done when i maintenance the engine, but those 2 misfires , wuts the fastes way to check that?
Old Sep 26, 2007 | 04:34 PM
akielb's Avatar
well #1 when were the codes last cleared - we need to make sure we're not trying to fix something that caused a code 2 years ago.
#2 Cam sensor can be replaced by removing the top timing belt cover - just clips on, you can do it without removing the front of the car( I think)
#3 Misfires - clear the codes - see if they both come back -if they come back, switch CP's #1 and #4 with #2 and #3 - if the misfires move with the coilpack/s - buy a new coilpack for each one that is misfiring - if they stay on #1 and #4 - change spark plugs
Now time to think worst case scenario - Your cam position sensor is telling the truth and your TB has jumped a few teeth and is causing the misfires. no idea now to check that with out taking off the head and and checking TDC.
Old Sep 26, 2007 | 04:45 PM
zat0rsk1's Avatar
hey , i cant thank you enough for ur time and help , i am gonna do exactly wut you said , thanx alot man , i will get back to you
TY!!!
Old Sep 26, 2007 | 04:51 PM
Audi_Skydiver's Avatar
I know that the CTS (coolant temp sensor) can cause lots of problems. When mine went out it cause a few random misfires, wouldn't idle right, and was a pain to start the engine if it was already warm. Try changing that first (only like $40 from the dealer) and see if it helps out with stuff.
josh
Old Sep 26, 2007 | 04:55 PM
akielb's Avatar
No prob - I'll subscribe so I don't miss your update
