GRRRR
Old Feb 6, 2007 | 07:02 PM
Lazer Viking's Avatar
Default GRRRR
okay so i was pulling into my parking space at school this morning and my steering starts to whine
i get out and look and there is almost no fluid (shlt) well i get done my stuff at school and go to limp home and there is fluid in my spot
so there is a leak i get home and take off the belly pan, rule out the pump and the rack and the high pressure line
then i start the car and turn the wheel and notice the little hose (return line) has a little hole in it... like a mouse had chewed on it
so my question does anyone happen to know the diameter of that hose (so i can patch it with some fittings and hose)
because i am not going to pay 60 bucks for a new one, nor do i feel like tearing enough of the car apart to get to the line on the pump in these sub zero temps.
also i read on audiworld that you can run mobil 1 atf fluid insted of the pentosin stuff, true ? should it be the dextron atf ?
i dont want to go all the way to the audi dealer to pick up that stuff and my dad can get the atf at work tonight
thanks.
Old Feb 6, 2007 | 07:11 PM
Dj Spiel's Avatar
Default RE: GRRRR
tape it
Old Feb 6, 2007 | 09:35 PM
tractioncontrol's Avatar
Default RE: GRRRR
ORIGINAL: Dj Spiel
tape it
LOL let me know how that goes for you.
Old Feb 6, 2007 | 09:39 PM
Default RE: GRRRR
it's 3/8's hose for future refernce to anyone that finds this
i will fix it in the morning and let you guys know how it went
(and it was a mouse that chewed through it (i found terds) (glad it wasnt my wiring))
Old Feb 6, 2007 | 09:48 PM
Default RE: GRRRR
Glad to hear you didn't decide to tape it.
Old Feb 6, 2007 | 10:18 PM
Default RE: GRRRR
yea, im assuming tape wouldnt stick to well over power steering fluid anyway
Old Feb 6, 2007 | 10:28 PM
Default RE: GRRRR
When you hit the stops on each side of the rack (wheel fully turned) the low pressure line becomes a high pressure line because the rack releases all of the extra pressure through the low pressure side and would blow the tape off. Make sure to get hose made for the p.s. return lines. Sounds like you should have no problems.
Old Feb 7, 2007 | 01:40 AM
Default RE: GRRRR
well if thats true then why would there be a designated "high pressure line" with a banjo fitting
and this one is just kinda clamped onto a fitting ?
TKneedsS4
Sep 13, 2007 10:16 PM
slowandrugged
Apr 25, 2007 02:10 AM
Black_97 A4
Apr 23, 2007 04:07 PM
lidonnit
Jul 31, 2005 11:56 PM
