gurgling sound when doing boost leak test
Old Apr 24, 2007 | 06:37 PM
akielb's Avatar
Default gurgling sound when doing boost leak test
well a few weeks ago I did a DIY boost leak test (a4mods.com). I had a gurgling sounds coming from inside the engine. is that normal? was I just pushing air into the crankcase via the crankcase breather?
one more question - If I wanted to redo all the vac lines in the engine, how many feet would you guesstimate I would need.
Old Apr 24, 2007 | 06:40 PM
onepoint8tee's Avatar
Default RE: gurgling sound when doing boost leak test
You obviously didnt plug the throtle body/throtle body boot. Youre supposed to or else the test is pointless. Id get about8 ft of vac line
Old Apr 24, 2007 | 06:42 PM
SacTown_Vlad's Avatar
i think i replaced all of them on my… i had about 6-7 feet and I still have about 2 feet left… 7-2= 5 feet should do
Old Apr 24, 2007 | 06:54 PM
akielb's Avatar
ORIGINAL: onepoint8tee
ok thats not part of their DIY right-up. I'll take a look at my bentley tonight and figure out what else I need to plug. but if you want to tell me right now that would be ok to
Old Apr 24, 2007 | 06:57 PM
techbod's Avatar
no idea hear but its sounds like a vac leak
Old Jun 21, 2007 | 03:53 PM
akielb's Avatar
Well I was just PM'ing with X1rider since he designed the boost leak test. and this was his responce for people that search and find this thread
Hi, I get the exact same thing when I do my boost leak tests, with the crank vent plugged up. As far as I know, it's normal, it's just some of the pressurized air making it's way past the piston rings, down to the oil pan. I'm pretty sure I remember reading somewhere that it was exactly what was happening.
and I did do what 1P8T had suggested of plugging the TBB but it didn't make a difference.
Mike02A4
Apr 26, 2010 02:59 PM
josh_easlon
Jun 10, 2009 12:14 AM
oldgearhead
Aug 18, 2008 08:18 AM
erikas3
Feb 12, 2008 08:15 PM
98A498
Dec 19, 2006 12:44 AM
