has anyone ever done a TBA on a 96 a4??
Old Jun 6, 2005 | 04:11 PM
pliddy's Avatar
Default has anyone ever done a TBA on a 96 a4??
im trying to do it with my vag-com and its not working... the instructions are pasted below from ross tech..
BUT, for some reason, when i plug in GROUP 098, or 060. i get a error invalid message...!!!!
what am i doing wrong?? can it be done fro a 96 a4?? thanks [:@]
Procedure for performing a Throttle Body Alignment on Cable-Throttle Cars:
These are cars with a physical cable between the accelerator and the throttle, but WITHOUT an ISV.
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Group 098 (Note: use Group 001 for ADY and AEE engine code)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
[Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
Procedure for performing a Throttle Body Alignment on DBW Cars using KWP-1281:
(Check to see if the engine speaks KWP-1281 by looking in the top left of the Open Controller Screen Some examples of KWP-1281 engine controllers are 2000+ Golf/GTI/Jetta/New Beetle/Audit TT 1.8T)
[Select]
[01 - Engine]
Group 060
[Go!]
Procedure for performing a Throttle Body Alignment on DBW Cars using KWP-2000:
(Check to see if the engine speaks KWP- 2000 by looking in the top left of the Open Controller Screen Some examples of KWP-2000 engine controllers are 2002+ Audi A4, 2002+ VW Passat, and Touareg)
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 060
[Go!]
It should say "Basic Settings: OFF" on the top of your screen.
Click [ON/OFF/Next] to turn on Basic Settings.
It should now say "Basic Settings: ON" on the top of your screen.
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
Click [ON/OFF/Next] to turn off Basic Settings.
It should now say "Basic Settings: OFF" on the top of your screen
Click the [Done, Go Back] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this![:@][:@]
