header for 98 1.8t
Old Aug 24, 2006 | 02:07 PM
elvis12's Avatar
Default header for 98 1.8t
anyone know of someone that sells a header for a 98 1.8t fwd for a k03 turbo
i have looked at many sites, but no luck. heder for big turbos, but not k3
i just got a new turbo, and wanted to put a header, turbo, highflow cat, and new down pipe...all at one time.
if you are asking, why a new k03, well i am happy with the way the car is running now, ( tap stage 2 710 k&n milltek cat back Throttle Body mod)
and figured a ported new turbo and the other goodies, would add a few hp, and run relible for a good long time, without cracking the block open and upgrading .
as always any input is good....
thanks
E
Old Aug 24, 2006 | 02:23 PM
Adam@mvp's Avatar
Default RE: header for 98 1.8t
technically its called an exhaust manifold for turbo's
Exhaust manifold
maybe that can help you.
another manifold
Old Aug 24, 2006 | 02:24 PM
tooxtreme8813's Avatar
yes renn-art makes one that is idea for BT and K03/K04. here is the link https://www.renn-art.com/Main.asp?make=1
Old Aug 24, 2006 | 02:25 PM
go to products, then click engine, find 1.8T(B5), and scroll half way down the page its called the ATP high flow manifold
Old Aug 24, 2006 | 02:29 PM
elvis12's Avatar
thank you
i was calling it the wrong thing.......
and thanks for the sites
E
Old Aug 24, 2006 | 02:31 PM
InsaneHatter's Avatar
dont waste your money... seriously .. a k03 is not going to flow enough for the stock mani anyway...
Old Aug 24, 2006 | 02:33 PM
onepoint8tee's Avatar
Youd have to do a HELL of a lot more than what you are talking about to have to open the block and do internals. Thats not really necessary unless you are exceeding 300hp.
Old Aug 24, 2006 | 02:37 PM
AEB is good for 400bhp, on a safe side you can go lower...
400bhp = 312AWHP.
You would need to run a 2871R or higher before you open the engine to replace the rods.
after rods, you wont have a problem unless you have a bad tune.
Old Aug 24, 2006 | 02:38 PM
Adam@mvp's Avatar
well he does not have stock turbo's he said he had a "BT"
Old Aug 24, 2006 | 02:39 PM
elvis12's Avatar
will the high flow manifold get the turbo spinning a bit quicker,
more or less lag????
E
