Headlamp comes on when i press brake pedal
Old Nov 25, 2004 | 10:27 AM
Pedds's Avatar
Default Headlamp comes on when i press brake pedal
Sorry for double post but i didnt get any replies on the A6 forum
As the topic says, just recently i've been having the warning indicator on the dash flashing when i depress the footbrake, i checked the break lamps and theyre working fine, tonite i pull onto the drive against the garage door and i see the side headlamp (nearside) flash on/
I know its probably a short circuit, but the electrics havent been touched ever.
Any help will be apprecaited.
Thx
Btw A6 2.5 tdi red i on the 98 plate
Old Nov 25, 2004 | 06:47 PM
g00se2's Avatar
Default RE: Headlamp comes on when i press brake pedal
hahah
Old Nov 25, 2004 | 08:01 PM
King_D's Avatar
It is pretty funny but i bet it is annoying. just disconnect the bulb untill you figure out whats wrong
Old Nov 26, 2004 | 07:29 AM
Pedds's Avatar
ORIGINAL: g00se2
hahah
Yeh thx for that, idiot
@ King_D Yeh its very annoying, and its becoming dangerous, cos people are thinking i'm flashing them.
Old Nov 26, 2004 | 11:37 AM
david9999's Avatar
I'm afraid I'm not going to be much help either. You might want to see if there may be a short in the rear lights such that the brake light is feeding back into the system. But this would not cause headlights to go on if they were off. Are you sure it is the headlight or is it one of the side markers or side bulb of the headlight? Have someone tell you which is going on.
You may also want to check the relays if the headlights are going on.
I'm just guessing right now, sorry.
Old Nov 26, 2004 | 12:18 PM
CRAZYHAWK's Avatar
Pull up to a wall and put the low beams on. Press brake. If no additional lights appesr, drive this way, until you find the problem.
Old Nov 26, 2004 | 12:27 PM
Pedds's Avatar
ORIGINAL: CRAZYHAWK
Yeh it is the side light thats are coming on.
Will have a look this weekend but until now i will drive with side lights on (so simple why didnt i think of that) DOH!!!!!!
Old Dec 1, 2004 | 01:15 PM
Pedds's Avatar
Ok, problem sorted, only posting a reply incase someone else has a similar problem.
It was the bulb that needed replacing, it really was that simple.
The bulb that was in there was working fine but it was shorting and making the sidelamp come on (there on the same loop)
Strange, but true
Old Dec 1, 2004 | 03:16 PM
Jestnomen's Avatar
6th Gear
huh, glad you sorted it all out.
Old Dec 2, 2004 | 01:07 AM
david9999's Avatar
