Headlamp washers
Old Jan 12, 2003 | 03:08 PM
BoostedA4's Avatar
Default Headlamp washers
Mine don't work... I checked the fuse, it didn't seem burnt, but i switched it with a vacant fuse and it didn't fix it, so i switched it back, and now am stuck. I have a '98 A4 1.8T, anyone have similar troubles or know how to fix it?
Old Jan 12, 2003 | 03:11 PM
Firestarter1984's Avatar
Have somebody else pull the trigger and see it those things lift up at all. Also check the windshield washer level because they are activated by water pressure and when there is not enough pressure they wont work.
Old Jan 12, 2003 | 03:13 PM
BoostedA4's Avatar
will do
Old Jan 12, 2003 | 03:33 PM
BoostedA4's Avatar
Nothin doin. filled it up, sprayed for more than 1 second, headlamps werent wet.
Old Jan 12, 2003 | 04:06 PM
i dont know them, never heard of that problem. since headlight washers are activated by water pressure there is no water going there at all, so it might be a ruptured line or something...</P>
Old Jan 13, 2003 | 03:10 AM
Mike_post whore's Avatar
In case you did not know...</P>
The headlights have to be on for the headlight washers to work. Once the headlights are on pull the wiper stalk like you normally would and all should be fine.</P>
You will see the spray come up from the headlights since it is pretty high pressure. </P>
Also, headlight washer failure is a COMMON problem...bring it to the dealer if all else fails.</P>
Old Jan 24, 2003 | 01:05 AM
dippi's Avatar
ya i have the same problem, i also have a 98 a4 1.8 t and the headlamp washers burned out on me, i was using them one day and they just did not pop up. I think the motor is bad, because i hear them do something, like as if they pop up, but they don't, and they don 't even spray the solution, so...</P>
any solutions...</P>
Old Jan 24, 2003 | 01:07 AM
dippi's Avatar
i know the lights have to be on...
Old Jan 26, 2003 | 07:13 PM
hb972.8q's Avatar
mine didn't work when i got the car..when i went to an audi dealer for some repairs they fixed it for free. didn't notice they did it until i used them a few days later...checked the bill and had n/c next to how ever they worded it.
Old Apr 21, 2004 | 01:55 AM
Mehurrman's Avatar
how will it work on my a4 the headlight washers, all i know is taht my headlights have to be on, does it turn on when i use my windshield wipers or does it turn on when it rains
